Question about Zebra LP 2844 Thermal Printer
How do I get Fedex label printer to print from other programs??
    Champion:
  • Zebra Expert
  • 285 Answers
Eack software have diferent wais to talk with the printer,
or send the comands to the printer (zpl files) and like this, he can send the printer configuration direcly, or can use setings from the driver.
if you go to Printer and Fax, right click on the printer driver, go to "properties" and print the test-page.
If print text plus the windows logo, that meens the printer is comunicate, now the rest is with the each software.
Posted on Nov 12, 2010
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
Zebra Eltron 2844 is not printing 4x6 shipping labels. I am using the printer to print FedEx labels. i recently had to reinstall the driver, and now when I print, it prints just under 2x4, rather than the...
You can recalibrate it to read the label size by doing the following.
Power off the printer
Hold down the green button
Turn the printer on and about 1/2 second after turning it on, release the green button
It will print out some information and measure the label. Once it stops, hit the green button one last time and then try to print another label.
Jan 26, 2011 | Office Equipment & Supplies
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Jan 14, 2009 | Office Equipment & Supplies
Lexmark x125 wont print certain items
I had the same problem printing FedEx lables. Solution for me was: Start>Control panel>Printers and faxes>right click on printer icon>properties>advanced>click on "print directly to printer". That did it for me. No reboot needed Mine was on Spool print. don't know how it got there
Sep 03, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
229 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
