Question about Canon ZR90 Mini DV Digital Camcorder
I have a canon zr90 camcorder and I just bought a Sony SDHC card for it, 16GB, it keeps prompting a card read error and im not sure why. Can anyone help?
I myself have been looking into buying a larger card for my zr90 as well. What I believe your problem might be is the camera does not support a SD card that big. The HC stands for High Capacity and the camera probably cannot read it. I'm still searching for the largest capacity card to use, I would guess it is going to max out around 2GB. Hope this helps!
Posted on Nov 22, 2010
Canon sd600 wont read 16gb memory card
No. The SD600 works with MMC and SD cards, which max out at 2GB. It will not work with SDHC cards such as your 16GB card.
Apr 16, 2014 | Canon PowerShot SD600 Digital Camera
Whats the largest sd card i can use.
The GZ-MG57 works with SD cards. Your 16GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in devices not designed to work with SDHC cards. You need to stay with SD cards, 2GB and smaller.
Jan 16, 2012 | JVC Everio GZ-MG57EK Camcorder
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Nov 26, 2011 | PNY Attach? 16GB USB 2.0 Flash Drive
I keep getting an error card message with my new 8 gb sdhc car I bought
The ZR 200 uses standard sd cards. It will not work with an SDHC card.
Nov 09, 2010 | Canon ZR200 Mini DV Digital Camcorder
Will my canon ixus 60 take a 16gb memory card
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Jul 12, 2010 | Canon Cameras
I bought a 16GB sandisk sdhc card for my Cnaon Elura 100. It says card error and will not initialize. What next?
Your camera is designed to use SD cards, not SDHC cards which are a later evolution of the SD card with different technical standards.
Your fix is to either stick with mini DV tapes or with SD cards with a maximum 2GB capacity.
Jun 30, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Failure to initialize and use memory card SD/SDHC / canon fs100 camcorder
I had the same problem but fixed it by initializing the SDHC Card. It explains it in the manual. If you go to the menu and then down to the card it gives the option to initialize it. I did that for all my cards and now they work fine. Hope that helps...
May 28, 2009 | Canon FS100 Flash Media Camcorder
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR90 Mini DV Digital Camcorder Logo
163 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
