Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. Throtlle is in full mode as per riding lawn mower directions.
  • 520 Answers
This is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Posted on Nov 13, 2010
21" Troy Built Self Propelled lawnmower engine won't start.
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
Jul 30, 2013 | Garden
I have twin 135 hp Yamaha outboard engines. Neither engine will start when cold.Putting small amount of gas into air intake and engine starts, engine starts fine when hot. Choke solenoid working
just like a car before the car start the fuel pump shoots gas in the carb or a lawnmower you gotta prime it all the gas that was in the carbs when you shut them motors off has done evaporated check your fuel cells see if there is a hand pump to prime the carbs unless its electric fuel pumps either way them carbs have to be primed
Dec 22, 2012 | Motorcycles
Lawnmower engine starts then shuts off. i put in fresh gas and it still does the same. I checked the oil level and its ok.
I assume your mower is starting when you "Prime" it with the plunger. That is forcing enough gas into the carb to start it, but then the gas is not flowing freely on its own. I'm guessing it sat with some Ethanol gas in it and needs a good carb cleaning, as 90 percent of what I work on, this is the case. I'm linking you to a great video which will show you how to do your carb, if you are so inclined. Best of luck to you.
James
Link: http://www.youtube.com/watch?v=ArCAivgAyww
Nov 05, 2011 | Briggs & Stratton Briggs Stratton...
I ran out of gas, now it won't start. what do i do?
Okay....I think your bike may have a vacuum operated fuel petcock.....which is the fuel valve on the bottom of the tank. It shuts the fuel off automatically when the engine stops and the hose from the intake to the side of the petcock loses vacuum.
So when you restart the bike the petcock is closed till the engine starts...which is okay because there is a small amount of fuel in the carb.........until you run out of gas....then the engine quits and the carb is empty.
To handle this situation, typically there is a prime position on the petcock that allows flow without vacuum to "prime" the empty carb......usually marked as PRI on the petcock,
So rotate the lever on the petcocck to prime....wait a couple minutes....get the bike started and set the petcock back to the normal setting....don't leave it on PRIME as fuel may flow overflowing the carb.
Apr 04, 2011 | 2007 Yamaha XT 125 X
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
184 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
