Question about Casio FX-9750GPlus Calculator
How do i use trigonometry to find out the angle in a triangle? which buttons do i press?
  • Casio Master
  • 8,064 Answers
Sorry to say it, bu Mathematics is not Mathemagic: you cannot do things with the shaking of a wand.
There are several ways to find one angle in a right triangle when you have the measures of the sides. You must have the triangle drawn in front of you and then decide if you use the sine, the cosine or the tangent. I cannot presume to know what your triangle looks like.
I suggest you look at the definitions of the trigonometric ratios and find out what is given in your problem.
If you use a ratio to find the cosine, you can then use the arcsine function to find the angle.
If you use one particular ratio to find the sine, you can then use the arcsine to find the angle.
If you know two sides a and b and you know the angle (B) opposite side b, you can use the sine formula (sin(A)/a=sin(B)/b) to determine sin(A) then use the arcsine of the result to get angle A.
Do post a comment to this thread with the case you are trying to solve.
Posted on Nov 26, 2010
  • k24674 Nov 27, 2010
    OOPS. The line 'If you use a ratio to find the cosine, you can then use the arcsine function to find the angle.' should read 'f you use a ratio to find the cosine, you can then use the arc cosine function COS^-1 to find the angle.'
A right angle triangle with length of AB 10cm and AC 20cm, how do I find the angle of BC
Assuming that the angle at A is the right angle, Pythagoras' theorem says that the length of the hypotenuse (the side opposite the right angle) is the square root of the sum of the squares of the other two sides. In your case, AB and AC are 'the other two sides' and BC is the hypotenuse, so:
/ 2 2 /
length BC = V 10 + 20 = V 100 + 400
= V 500 = 22.36 cm
(To find the angle at C, you need trigonometry and is arc-tan(10/20)
and the angle at B is arc-tan(20/10) - 26.5 deg and 63.5 deg)
Oct 17, 2014 | Computers & Internet
Offset is 8 in run is 6ft 3 3/8in travel is 6ft 3 13/16in. How do I find the degree?
If I understand your terminology correctly, you have a triangle with a hypotenuse of 6' 3-13/16" and a side opposite the angle you wish to find with a length of 8" (and a side adjacent to the angle you wish to find with a length of 6' 3-3/8") Trigonometry says that the sine of an angle is the length of the opposite side divided by the hypotenuse. (all units must be the same, so convert everything to inches)
So sine (angle) = 8/(6 * 12 + 3 + 13/16)
sine (angle = 8/(75.8125)
sine(angle) = .105523
angle = arc-sine(.105523)
angle = 6.0573 degrees (from tables, calculator, computer etc)
Jun 07, 2014 | CyberEd Trigonometry Problem Solver
How to calculate angles
if it is a right angle triangle then you will need trigonometry to do so.
Nov 29, 2013 | Office Equipment & Supplies
What is trigonometery
Hi, Trigonometry is defined as: The branch of mathematics dealing with the relations of the sides and angles of triangles and with the relevant functions of any angles. See more information on trigonometry by clicking here. Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Computers & Internet
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
Can you gave me a example of a right triangle problems?
In right triangle we are making 90 degree angle triangle, we can have problem for finding hypotenuse or finding sin or cos values of the side of the triangle. For ex,Find out the hypotenuse,sin and cos value of the right triangle with base 4 cm and perpendicular 3 cm Solution:Hypotenuse = SQRT(4^2 + 3^2) =SQRT(4*4 + 3*3) =SQRT(16+9)=SQRT(25)=5 cm For right triangle, sin(x)=3/5=0.6 cos(x)=4/5 =0.8
Jul 16, 2010 | Super Tutor Trigonometry (ESDTRIG) for PC
How do i use tan on my calculator
Tangent is a trigonometry term. It is used to find the Opposite/Adjacent ratio when given an angle measure in a right triangle. The proper syntax is tan(angle measure).
Dec 17, 2009 | Computers & Internet
This is a right angled triangle. A radio mast is 36m high(opposite), and the angle (adjacent) of elevation shown is 63 degrees. Work out the length of the hypotenuse.
It is not clear which angle you are talking about...
In one case the Hypot = 36/(cos(63)) meters. (about 79 meters)
The other case Hypot = 36/(cos(90-63)) meters (about 40 meters)
Sep 12, 2009 | Super Tutor Trigonometry (ESDTRIG) for PC
Trigonometry
Hi Jehho soria
Draw a right triangle with the vertical portion of the triangle representing the 37 meters of the light house The base of the triangle is the distance we are trying to find. If the angle of depression is 15 degrees, the other angle is 75 degrees. This is the angle from the boat to the top of the lighthouse.
so The Tangent of 75 degrees is equal to the side opposite the angle (the height of the lighthouse) divided by the side adjacent (the distance we are trying to find.
solving for the distance we get distance = 37 divided by the tangent of 37 degrees
Looking up the tangent of 15 degrees on google give .2679
dividing 137 by .2679=138,1 meters
Hope this helps Loringh PS Please leave a rating for me.
Nov 14, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Casio FX-9750GPlus Calculator Logo
274 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
