Question about ASUS Eee PC 1000H Laptop
Trying to output to tv which tab do i press - ASUS Eee PC 1000H Laptop
  • halvershouse Nov 13, 2010
    the F(*) which one is that? I guess I'm dumb
  • 416 Answers
Hold the Fn key and press the F(*) key the has a solid or clear rectangle or square to activate the remote monitor
Thanks and pls rate this post!!!
Posted on Nov 12, 2010
  • Remote Computer Rescue
    Sry F(*) refereed to all possibilities of F as a function key.
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
Connecting my macbook pro to digitrex tv using thunderbolt and hdmi
DisplayPort to HDMI Sound is actually set up by using the MIDI setup utility found in :
Applications > Utilities > Audio MIDI Setup.
If you purchased an iWires cable direct from Apple the instructions are in the printed booklet that comes in the packaging. Most people don't read this as it's normally the case that when you plug a cable in to anything it just works (VCR, TiVo, Xbox, video camera etc). In this instance Apple are failing to live up to their catch-phrase as final setup is NOT intuitive; "it just DOESN'T work".
The booklet instructions basically say do the following,
Video
System Preferences > Displays. There are 3 tabs in the window; Displays, Arrangement and Color. Be sure you are on the Displays tab. Bottom left of the window tick "Show displays in menu bar" and then bottom right click "Detect Displays".
Now click on the tab named Arrangement. Bottom left of the window tick "Mirror Displays".
You should now only see 2 tabs, Display and Color. Be sure you are on the Displays tab. Select the desired resolution for your TV (probably 1080i). leave all other settings at their default values.
Sound
System Preferences > Sound. There are 3 tabs in the window; Sound Effects, Output and Input. Be sure you are on the Sound Effects tab. Middle of the window select your TV where it says "Play sound effects through:".
Select the middle tab named Output.
Select your TV from the drop-down list next to HDMI, below where it says "Select a device for sound output".
Using either Finder or Launchpad go to Applications > Utilities > Audio MIDI Setup.
On the left-hand side of the window you should now see HDMI. In the middle of the window, on the Output tab, where it says "Source:" select your TV from the drop-down list.
This last action below is NOT described in the iWires notes but was required in my case, it may also be required in yours. If you CANNOT see a speaker icon next to HDMI in the list on the left, do the following:
Bottom left of the window select the wheel icon with the down-pointing triangle. Make sure that sound output is selected and that you can now see a speaker icon next to HDMI in the list of devices.
If you still cannot hear sound, log out of your account and then log back in.
You may have to do some or all of the above to get sound out of your TV from your computer using the DisplayPort to HDMI cable. On my Aug 2011 MacbookPro I had to do ALL of the above. If you take your laptop to a different TV you will have to do it all again so be warned.
Hope this helps.
Feb 24, 2014 | Apple Computers & Internet
Want to use my tv as a monitor, how do I activate the vga output?
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope it helps
Jul 20, 2012 | ASUS Eeepc Eee Pc 1005 1005h 1005ha...
How do you hook up the tv to a pc? I have the cable but I cannot get the tv to recognize the pc?
You will want to make sure that your TV is set to the same input that you are using to connect your PC to the TV. From the PC side, depending on whether you are using a laptop or a desktop PC, you will have to change the output so that the computer will output to the correct connecter.
If you are using a laptop, there is usually an F key that will allow you to switch from the built in display to either an external device, or both internal and external. The F key in question will usually have an icon on it that will look like a monitor screen. Pressing that F key at the same time as your Fn key should allow you to switch the outputs.
If you are using a desktop computer you will have to right click on a blank spot of your desktop and choose Display Properties from the menu that appears. You will then choose the Settings tab, and then the Advanced button. This should bring up your graphic cards control program. Again, depending on what type of graphic card you are using you should see a tab called Monitor. Some graphic cards will also have special tabs with a heading like Display or something similar. On this tab you should then be able to choose your output from the normal monitor you use to an external monitor. Your desktop will then start feeding the graphic signal through that output rather than the one you would normally use.
If this information doesn't quite resolve your issue please post another question but specify what kind of computer you are using, what type of graphic card you have, and what output on your computer you are trying to use. I will then be able to give you specific instructions for your setup.
May 15, 2011 | LG 32LG30 32 in. LCD HDTV
Only plays in black and white? what do we do?
Try a different cable, and a different TV if possible to help narrow down the problem.
it could be set for some other peculiar output mode; go into the configuration in the dvd player menu and verify that it is set for the type of TV you are using. normal composite video, (RCA), SVideo, Component Video, RGB, VGA, and Progressive Scan.
Dec 01, 2009 | Apex Digital AD-1110W DVD Player
URC-50 Uninversal Remote won't control a Dish VIP 612 DVR. Both Companies say one is RF and the other IR so they can't "talk" to each other. How can a person "get around this" without buying another...
I don't know about the 612 but the 722 I have has green tabbed control for IR control of output 1 and by default of tuner 1 and controls the OTA tuner and will work with many IR remotes if set to address 1--they don't send the address. The blue tabbed one is for RF-controlled output 2 and tuner 2. Setting it to single (vs. dual) mode allows either remote to control tuner 1 and swap to tuner 2 and do PIP. Unfortunately the 612 does not have this mode.I haven't had a combo remote work well with tuner 1 even. It is much better to use the Dish remote for most of the work, well only volume and power on the TV. There are a lot of buttons most combo remotes will not have control of. Hey, I have 2 VIP722 and the TV remotes on the chair arm.Check with menu-menu to see which address code and control mode is set. But if manual allows and you can pull tab after opening battery slide and change switch beneath, you may be able to use as IR remote in preparation for your combo, just to be sure controls sent correctly. (Hold Sat button until all light, press address 1, press # to set remote [lights go out], then press record to set receiver while you watch menu-menu. less than 10 sec per step.)-Ken
Jul 15, 2009 | Kenwood RC-R0720 Remote Control
View laptop on tv
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
Mar 23, 2009 | Dell Computers & Internet
About my MPC T3000 Laptop
there should be a button like f4 that switches hold down the fn key & press the key with the 2 screens on it.
Jan 16, 2009 | MPC Computers TransPort T3000 Notebook
No composite video output
To activate the TV output, the Fn + F? would have to be pressed. This is to cycle through the choices such as LCD, TV + LCD or TV olny. F? would be the function key with the small monitor icon. Additionally, it is required that the Screen Resolution in the Settings tab of the Display Properties be lowered down to match the capacity of the TV. Most/regular TVs can only display 640 X 480 or 800 X 600. In some cases, it would also be necessary to lower down the Screen Refresh Rate sometimes as low as 60 Hz.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | HP Compaq Evo n600c Notebook
ASUS Eee PC 1000H Laptop Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
