Question about Ovens
Norge Oven BNEW3H9TZ-EW ser #57C..... Both elements in the oven do not work. When switched to self clean, nothing comes on. Most likely blown controller and/or relay board. Is this correct? Fuses are all OK. Are these parts available? How much Bish
catriver
  • 878 Answers
SOURCE: Our oven's heating elements will not come on althought the display seems to work correctly.
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. Catriver..post back.
Posted on Dec 18, 2006
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 33 Answers
    SOURCE: Oven does not work after running self cleaning
    Dear Dupe,
    please rate this solution if it mends up ur needs,else choose fixya,
    please do the following checks,
  • Test the element
  • Check the thermometer bulb
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    • 1531 Answers
    SOURCE: My oven says that it's on (heating up or cleaning,
    no i do not think your elements are bad.it soundsd more like the main control board has malfunctioned.
    Posted on Sep 16, 2009
    Testimonial: "Thanks, I'll take a look."
    Oven won't heat
    You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
    Oven Failure After Self Clean and F1 Errors
    Aug 22, 2014 | KitchenAid Ovens
    No power after self cleaning
    Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
    1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
    2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
    3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
    4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
    5.
    6.Even a bad relay door switch will hinder your oven from operating.
    If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
    Dec 14, 2013 | LG LWD3081ST Electric Double Oven
    I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
    Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
    Dec 16, 2010 | Ovens
    I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
    You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
    Aug 07, 2010 | Hotpoint Ovens
    All elements cease to work after self clean
    If the electronic control is blank then an inline fuse to the control has blown due to overheating in the area of the controls. If the controls are visable but nothing in the way of high voltage works then that is the limits in the rear of the ovens.
    Feb 15, 2010 | Thermador SMW272 Electric Double Oven
    Self cleaning oven won't unlock after cycle is complete
    Unplug it for about 30 minutes, plug it back in and see if it unlocks. If not, then the latch, interlocking microswitch or control board is faulty. Also look for any bad connections (make suer the power is off before you start wiggling connections).
    May 21, 2009 | Ovens
    Ge wall oven will not heat up on bake,boil or clean cycle
    GE JKP86BF3BB COMBO MICRO/ELECT OVEN
    NO HEAT ON BROIL OR BAKE ELEMENTS
    CKD WIRING FROM PANEL OK
    CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
    FAN COMES ON
    THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
    MICROWAVE WORKS FINE
    I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
    STUMPED
    Mar 16, 2009 | GE JTP15 Electric Single Oven
    Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
    Smeg single fan oven
    You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
    May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
    Ovens Logo
    55 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
