Question about 2wire (1000-400108-001) Router
I ahve an AT&T 2Wire wireless modem/router (2700) and am trying to talk to an XBox on the other side of my house. SIgnal is too weak. I called AT&T and they supposedly went on my DSL line and boosted the settings on the 2Wire. How do I confirm they did it and how can I adjust it up since it didn't make much difference? Even so, is there a better way to boost the signal across my house?
  • david_rob773 Nov 16, 2010
    Thanks. Didn't solve my weak signal problem but it did allow me to change the settings.
    Guru:
  • 2,178 Answers
Open the Command Prompt from the Accessories folder from all programs. Type "ipconfig" and hit enter. Note the Default Gateway ip setting - xxx.xxx.x.xxx. Enter this value in the URL address field of your browser and hit enter. This will open your modems settings page - read and select the page you need to change your values - such as the wireless power adjustment. There are some sections that will require a password to change - you or your ISP should know the password.
Posted on Nov 12, 2010
How do I boost the signal from an at&t 2wire dsl modem so that the signal will work better in some parts of the house.
for wireless signal 1st thing to consider is the EMI's (eletro-magnetic interference) anything that is near that modem that produces static electricity, radio frequency and magnetic energy (eg. cordless phone, speaker, anything electronic...) isolate the modem at-least 6 feet away from this said EMI's.
2nd you may check on the the wirelss settings on your modem's GUI(interface) see the link:http://support.2wire.com/index.php?page=view&article=60
wireless channel and power settings and the only once you should change... channel such as 1,6,7 are sometimes used by other device (wireless phone, neighbor's router) power settings: as you place it on a higher number it gives longer distance but gets thinner space(area)
consider the red signals as you place the power higher the signal gets longer but thiner.
lastly wireless doesnt penetrate walls/ glasses it only bounce back and forth to it... so less wall or interference the better chance of going directly to the access point...
if you really havea big house try consider buying wireless booster/repeater...
Sep 02, 2011 | 2wire (1000-400108-001) Router
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
Dec 30, 2009 | 2wire HomePortal 100W Router...
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
2wire gateway signal range problems
1. Put the router in the highest location possible in the house.
2. Make sure the gateway is installed in the center of the house rather than in a corner of house, so it will cover area on all sides.
3. Make Sure you dont have any devices that may interfere with the signal eg. cordless phone , close to the gateway.
4. Use channel 3 or 7.
Mar 23, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Can't get connected
try reset switch on back unplug it al then back in try again
Feb 04, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-400108-001) Router Logo
769 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
