Question about Sport & Outdoor - Others
I have a new Nova Optimus Stove right out of the box, put kerrosene fuel in bottle triend to pump it up by the directions, now pump is not working appears leather is gone where do I get anothe one? What did I do wrong? I live in Vancouver BC Canada
    Top Expert:
  • 76,109 Answers
Hello
First off please read about the recall of these stoves for a fire hazard. Go to the link below.
optimus
-multifuel-expedition-stoves-due-to-fire-hazard/">http://www.optimusstoves.com/seen/service/newsroom/detail/article/2010/09/27/katadyn-products-inc-recalls-optimus-multifuel-expedition-stoves-due-to-fire-hazard/
At the same page you will find a link to Katadyn Products Inc, the makers of the stove, contact them on the parts you need. Here is the contact link you need.
http://www.optimusstoves.com/seen/service/kontakt000/
Posted on Nov 12, 2010
I got water in gas tank but dont have money to drop tank what other options car cranks but cuts off when put in drive doesn't seem like its getting gas what should i do will gas treatment work?
Hi Stacy
Fuel treatment would be your cheapest option by far. Give it a shot, paying attention to the directions on the bottle. You certainly can't hurt anything by trying it.
Good Luck
-Steve
Jun 06, 2015 | 1991 Buick Park Avenue
I'm traveling to South America and I will be camping there a lot. Can I bring a liquid fuel stove on the plane?
You can put a stove with an empty fuel bottle in your luggage that will go in your checked luggage (under the plane, not the carry-on luggage). However, if there's gas or any fuel in the bottle, there is no way they will let you bring it on the plane. So just make sure it is clean and free of any gas or fuel.
Oct 25, 2012 | Camping, Backpacking & Hiking
I cant get fuel to fuel filter i put a new fuel pump on but nothing?
Can you put air compressor line to end of gas line that comes from tank and blow air into tank then you would know if there is a blockage between filter and tank? Also are you sure you have inline filter inserted in the right direction most only work in one direction.
Apr 14, 2012 | Garden
Hi It is almost impossible to get my 86 1.6L Nova to start after being shut off for several hours (overnight) I put a new fuel pump & filter on which didn't help then put an electric pump on. Still...
Under hood fuel lines, touching coolant or heater hoses.
Fuel lines under vehicle close to or not shielded from exhaust pipe, converter, muffler. Fuel lines pinched or crushed.
Fuel filter changed recently.
Fuel pump pressure. Fuel pressure regulator & Fuel pressure sensor.
The age of your vehicle also guarantee's a vacuum leak. It may sound silly but the truth is rubber grommets, and hose's shrink and dry out over time and the harsh environment under the hood makes it worse. Check all vacuum lines and fittings attached to the intake manifold, valve covers (pcv valve), and be sure to check for a vacuum fitting on top of the intake just behind the throttle body. Does it fit tight in the hole? You can seal loose fittings with a high-temp RTV (Red) silicone sealant/adhesive. Several small leaks add up and your engine, heat/AC, and transmission will be all to glad to tell you about it.
Aside from that, if you are still having problems, Have a look at the MAP & Oxygen sensors. Finally, you may end up replacing the TBI throttle body assembly.
Aug 29, 2011 | 1986 Chevrolet Nova
I have use Coleman fuel in my stove..is that ok? Also can't get it started
The Optimus Nova is a multi-fuel stove. Coleman fuel will work in the Nova. Coleman fuel, generically called "white gas", is a chemically pure form of gasoline, same as what you put in your car but with less impurities.
The nozzles all liquid fuel stoves can clog from time to time. Follow the instructions in the manual for cleaning. If you don't have a manual you can find it at:
http://www.optimusstoves.com/seen/optimus-products/products/katadynshopconnect/optimus-outdoor-kocher/
Hope this helps.
Mar 29, 2011 | Optimus Nova Stove
After a valve job,new plugs wires and cap and rotor,the Nova purred fine for 62 miles then it died in traffic,acted fuel starved,sat with it for a while it started right up then died again. Had it towed to...
fuel pressure after it has been driven for a while. or the next time it dies hit the fuel tank at the pump and see if it starts. if it does you pump is diing
Jun 16, 2010 | 1986 Chevrolet Nova
1979 chevy step van 350 new fuel pump rebuilt carburetor wont sta
remove the fuel line from the carb, put it into a bottle, crank the engine, If the bottle has fuel in it the fuel pump is working properly, if not, check the filter, and the fuel lines to the tank!!!
Nov 02, 2009 | 1979 Chevrolet C/K 3500
Car wont start, install new fuel pump ,if u dump little gas in carb will run for a few seconds. ALSO THIS CAR SAT FOR YEARS NOT RUNNING
OK, first, let's clarify one point. Your 1986 Chevrolet Nova does not have a carburator, it is equipped with Throttle-body Fuel Injection.
You should be able to look into the throttle body and see fuel spraying from the fuel ijector while you are cranking the engine over. If not, then there is a whole list of things that could be causing the fuel to not spray. Here are some of the possibilities:
Low fuel pressure (for several possible reasons)
no B+ feed to injector (for several possible reasons)
bad crank sensor
bad PCM
broken injector wires
bad injector
If it runs with fuel poured down the throttle-body, it is definitely a fuel-delivery/fuel injection problem.
Oct 17, 2009 | 1986 Chevrolet Nova
Just fitted solid fuel stove with back boiler, water in system but not circulating through hot wwater cylinder.
is the circulating pump going in the right direction? if not reverse the pump if it is make sure your valve is not clogged going thru the pump, if it isn't a ball valve put one in, a gate valve could break off inside and it will still feel like it is working but it wouldn't be,
May 17, 2009 | Bosch & Power Vent Water Heater
Sport & Outdoor - Others Logo
23 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
