Question about Panasonic PT-LB50U Multimedia Projector
I have a panisonic pt-lb50ntu Projector. It will only focus the center of the image. When you adjust the focus to the bottom of the image the top and center are out of fucus. The same goes for focusing on the top.
  • 442 Answers
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Posted on Mar 16, 2011
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
Can't get lens to zoom in and out
DIRECTLY BEHIND THE FOCUS DIAL IS A SERRATED COLLAR TO ADJUST ZOOM SETTING TURN LEFT AND/OR RIGHT THEN REFOCUS
Apr 21, 2009 | Panasonic PT LC75U Multimedia Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Out of focus center of picture
Hi there
This could either be a bit of dust on the inside of the lens or the LCD's
Apr 15, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt-lb50ntea password problem
Hi Nexus
The unfortunate thing is that you cannot reset the password on this Projector externally. You will have to take it to a Panasonic repairer becausethey use software to reset the password.
You can download the manual for free from www.projectorcentral.com
Download the manual for the PT LB50NTU - it is exactly the same.
Mar 26, 2008 | Office Equipment & Supplies
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-LB50U Multimedia Projector Logo
176 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
