Question about Protron PLTV-26 26 in. HD-Ready LCD Television
TV does not show picture when turned on. Some times it does not come on. when it does it goes to a split Bright green screen, After that it will go to a lot of different screens with lines, full screens of different colors,etc. sometimes it will come on after pushing the power button off and on 50 to 100 times.
    Genius:
  • 1,126 Answers
It is possible that TV processor could have some garbage it do to a small voltage surge, and if you leave your set, unplug from the wall for 40 min,. that will reset it back to normal. If thgat don'rt work then remove the back and check for a couple of bulged electrolytic caps on the power supply nthat need change, or change out the power supply.
Posted on Nov 12, 2010
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Hi, tv set goes into standby,when you reset the picture is bright green for about 10 seconds and goes back into standby.
tv is drawing too much current and protection circuit kicks on and shuts tv down. try turning all screen controls all the way down. if that doesnt fix it, sounds like bad green picture tube. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
Bright green picture
defective green picture tube crt. suggest local service center
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Green Screen
Your picture tube is bad,pull back off/ unplug crt broad on neck of tube make sure it does not touch anything ,turn set back on if set stays on tube is shorted!
Dec 18, 2007 | GE 13R100T 13" TV
My screen turn bright green then shuts off on its own
It's your CG board. I have the same problem and looking to get it repaired
Nov 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
51 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
