Question about Brother IntelliFAX 4100 Laser Fax
When we send a fax the receiving party only gets a black sheet. how do we fix this? we have tried changing the contrast and resolution and cleaning the scanner and nothing is helping.
  • 1,110 Answers
Your document scanner has failed. Verify by making a copy with the machine. If it comes out black then your document scanner is dead. It will be cheaper to replace the fax machine rather than repair it. These types of machines have come down in price making it no longer feasable to make such a major repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 13, 2010
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Receive a black copy
scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Feb 26, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Hi, Remote Fax Error being displayed
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
Brother IntelliFAX 4100 Laser Fax Logo
59 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
