Question about Kodak i1220 Pass-Through Scanner
On my Kodak i1210 scanner, it passes the paper thru, but shows up with on long black streak. Can this be fixed & if so where can I find the parts for it.
Check if interal sensor is dirty oterwise needs new optical scanner, only fix if in warranty otherwise bin it!
Posted on Dec 23, 2010
My Kodak P811 scanner will not pull the paper thru.
I would check it there is a kodal service Hodak scanner service centre nearby to be honest...the last thing you want to do with a quality photo scanner is put it back together incorrectly. But I am cautious when it comes to electronic devices.
Jul 19, 2015 | Kodak P811 8x10 Personal Photo And...
Kodak i260 paper jam
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
Aug 03, 2013 | Kodak i260 Duplex Color Scanner
I have 6 identical new PC's running Windows XP SP3 with Kodak i1210 scanners. 4 of them are running fine and scanning fine. The two giving me an issue are scanning fine as well but they are scanning...
Please check if the disk where you are saving has enough space. Defrag the drive for better results. If you are connecting the scanners trough an USB cable, try replacing them. Also check if the file format is same. If you have chosen to scan BMP or TIFF uncompressed or Color, the file size may be too big. I presume the other two PCs are free of virus.
S. Mohan
Aug 09, 2010 | Kodak i1210 Pass-Through Scanner
Kodak I1220
Kodak i1210 the red led is flashing and no work
Jun 24, 2009 | Kodak i1220 Pass-Through Scanner
Streak down the middle of each scan
Make sure the scanner glass is clean and there are no foreign objects.
If the streak is a white line then it could be a ink cartridge problem.
Jun 23, 2009 | Panasonic KV-S2026C Pass-Through Scanner
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
HP L7780 Scanned images are all black
i think your batch's thickness is high. so that when you are keeping your batch on the scanner then your cover will be not covering properly. so that the external light will be passing through the gap between scanner and cover. so that your scanning is showing black. if you want to scan your batch, then you have to cover by plane paper around your batch on the scanner. otherwise you try to protect out side light on the scanner glass. now you can get proper scaning.
regard
priyabrata
Feb 16, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
Kodak i1220 Pass-Through Scanner Logo
281 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
