Question about Fujitsu Plasmavision P42HHA10 42 in. Television
I have Fujitsu TV. it hooked up VIA HDMI to a PS3 and it is saying that it is "out of range"
4 Suggested Answers
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
  • 1044 Answers
SOURCE: When i pug in hdmi cable and set to video 5, i get
On the video selection you have to go to HDMI and not video 5
Posted on Nov 14, 2009
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
My lg flatron n2294a - PM displays an "out of range" message and won't wirk with my ps3 when using the hdmi or AV option. Whats wrong?
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Apr 01, 2013 | Computers & Internet
PS3 HDMI
the tv more than likely the most sensible thing to do would be to check its not your cable by trying someleses that you know works. its sometimes the tv resolution or the playstation because some tv's do that, my laptop would sink and a say out of range but try someleses cable or different tv screen resolutions on picture settings
Jul 25, 2012 | Sony Video Game Consoles & Games
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Fujitsu Plasmavision P42HHA10 42 in. Television Logo
300 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
