Question about E-Machines T6524 PC Desktop
Wavy screen began to show up slowly and then as the puter warmed up, screen got normal. One fine day wavy screen stayed forever. Tried everything, driver update did'nt work, final decision: Onboard graphics card must be toast. Bought Sapphire Radeon HD5450 since puter meets or exceeds min requirements. Disabled old card in device manager. Went into BIOS, changed from onboard graphics to PCI express slot. Installed graphics card. On boot fans speed up and I get no screen and no boot, (yes I switched the VGA monitor plug into the new card). Scratch head....should of worked but it won't. A dozen times later no success. Only works with onboard card. Maybe update mobo BIOS?? Much googling and no info except mobo, (MSI MS-7184 wont support since BIOS is custom made for Emachines). No BIOS update available from Emachines either, (but will tech support for $149.99 an hour, sleaze balls)! No not PSU either swapped out with new one I stored and same issue arises. Found other case with same exact issue on Toms hardware but no responses. This puter was marketed with PCexpress upgrade slot but it dont work! Please help....anybody??
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
When I turn on my ps3, the initial music plays and the wavy bar comes up with the words "playstation 3" like normal. It then does nothing. The wavy bar stays on the screen and nothing happens. The color...
i had the same problem, i reset the PlayStation 3 video mode (when playstation is off hold the start button till you hear the second beep) and had to hook it up with the A/C cables and it got it working for me
Jun 14, 2009 | Sony PlayStation® 3 (80GB) Console
Aficio 200 copier
replace the laser scanner motor..approximately $144.00 dealer cost retails for $ 210.00 takes 10 mins to put in.
Oct 14, 2008 | Ricoh Aficio 180 Laser Printer
Kines on Screen and Fading
Open up the front of the set by removing the speaker screen and the black piece of particle board. on the bottom right you will see 4 knobs. Turn those knobs slowly till the arcs go away. The 3 knobs on the bottom are for color. the 3 on top are for the focus.
Jun 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Wavy screen
Try using a different refresh rate. I've found that when you change it down to 60 hertz that the issue usually goes away.
Jan 07, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Wavy picture on television screen
First do the self test on these threads or goto
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Toshiba 50H12 Rear Projection TV wavy screen
There is a Hyper Module mounted right behind the video inputs board. in most cases you can replace the 10uf surface mounts carefully not to tear the foil. and the set will return to normal. or replace the H/M board. this board is soldered 4 tabs on bottom of main board and then pulls out. good luck list of caps cz52(may not have this cap).. cx261 cx270 cx230 cx178 c514 cx221 cx250 cx241 cx541 cx670
Dec 11, 2007 | Televison & Video
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Open Questions:
See all E-Machines T6524 PC Desktop Questions
E-Machines T6524 PC Desktop Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
