Question about Samsung HCM653W 65" Rear Projection Television
Samsung HCM653W 65 in. Television
I had a repair man tell me my power regulator and high voltage regulator were bad. An idea on where I could find the replacement parts or if the entire board should be replaced?
Thanks in advance
Dear,
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb,sub.samsung part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per"Partsstore.com. I have no idea where you can find the power supply board. If you find it,please let me know.
Thanks.
DollarTech
Posted on Jun 23, 2008
What do i do if my tv says code 21
somethings wrong with the high voltage circuits and its not allowing the tv to work -to protect you from xrays!
I would send it to a professional repair man or splash out and buy an LED or plasma screen. Don't fiddle with it yourself as the voltages concerned are very dangerous
Jan 08, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Samsung HCM653W 65 in rear projection tv
its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
Aug 22, 2008 | Samsung HCM653W 65" Rear Projection...
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Skyassoc
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W
Convergence board will have 2 big black ics on it STK392-110s or 150s Use number on STK s in your set.To get parts call 1-800-223-3205 Electronix Parts.
Aug 25, 2008 | Samsung HCM653W 65" Rear Projection...
RGB COLOR PROBLEM.
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Apr 22, 2008 | Samsung HCM653W 65" Rear Projection...
The power has gone - Samsung LT-P266W
I need to know if there is a red led that is on, or if there are no lights at all that come on, it's important because it will tell which board to replace, if your trying to trouble shoot it down to the component that is bad, good luck with it. I would call in a repair man.
Mar 30, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Samsung HCM653W 65" Rear Projection Television Logo
63 people viewed this question
Henry  Thomas
Henry Thomas
