Question about Kenmore Vacuums
HAVE A KENMORE HEPA UPRIGHT MODEL 116, hOW DO i CLEAN IT IN SIDE , IT HAS VERY LITTLE SUCKING POWER
I have had my Kenmore 166 open a few times. There are several screws which need to be removed and a tab on each side next to the brush and a tab near the handle release lever. Use a flat head screwdriver to carefully open the tabs after the screws have been removed. You do not have to remove the screw holding the metal tab next to the handle release lever.
I have succesfully, but not easily, removed this bottom cowl a couple times without removing the wheels but it is not easy and reinstalling it is even harder. I suggest removing the wheel on the left side by removing the lock washer. Removing this wheel from the axle allows the entire axle to be slid out.
Reinstalling the cowl is a bit trickier and will require a new axlelock washer which you can get by taking the axle to any hardware store.
Posted on Nov 24, 2010
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
Powerforce stops;have to wait 30 min or so for it to come back on -low power remains on -- there is no clogging.
What is happening is the vacuum is overheating so the thermo fuse shuts i down until it cools off.
Does it have good sucking power? Check and clean all the filters. Especially the external hepa filter I beleive all these models have. You can even remove the external hepa filter on the side and see if it runs then. If it does you can bet its clogged and is restricting the motor exhaust.
Jul 02, 2011 | Bissell 6594 PowerForce Bagless Upright...
We have a Kenmore Progressive Model 116 Upright bagged vacuum with Hepa filter. It's at least a couple years old. For quite some time now when ever we use the vacuum the vacuum motor will shut off nafter...
I suspect that you have a restriction. The motor sounds like the thermal break is stopping the motor before damage, due to heat.
You must witness that the entire suction and discharge side are clear. This is not always very easy, but necessary. I bet that you find something blocking somewhere...
Nov 13, 2010 | Kenmore 34612 Bagged Upright Vacuum
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
My kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Mar 24, 2009 | Kenmore Progressive Bagless Upright with...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore sweeper model 116-33919
Go to sears.com, click on the parts link, enter your complete model number, then you can click on the links for your vac and you can figure out what it takes, and you can order thru there also.
Jun 05, 2008 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
100 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
