Question about Echo Pb - 413t Backpack Blower
Pull cord is stuck on my gas backpack blower - Echo Pb - 413t Backpack Blower
  • 68 Answers
SOURCE: cord won't pull out
Hi Shaun77b,
Regretfully if you didn't use a gas/oil mix the motor is probably seized. The internal parts on a 2 cycle motor are lubricated by the oil in the gas. It may keep running without oil but once it shuts off- its done.
Sorry, Phil
Posted on Dec 28, 2008
  • 103 Answers
SOURCE: repalce cord on gas blower
MAKE SURE YOU HAVE THE RIGHT SIZE CHORD FOR THAT STYLE,MUCH SMALLER THAN MOWER STYLE. ALSO PROBABLY HAVE IMPROPER TRACKING OF ROPE. TRY PULLING COVER BACK OFF AND MAYBE KNOT GETTING CAUGHT UP IN FLYWHEEL FROM ROPE
Posted on Jul 12, 2009
  • 148 Answers
SOURCE: i pull the cord but it will not start, i have a Ryobi Backpack Bl
Ok that's half the battle. Probably the easiest thing to do is to clean the carb. So I would get some carb cleaner and using the little tube that comes with it spray into the high and low ports on the carb. Then spray in the outlet side of the carb.
Ps. Remove the little black and white caps and turn the screws on each while counting the number of turns to close (this way when you put the screws back in then all you have to do is count the turns to put them back at the factory settings). Now remove the screws and gently put the tube in each port and spray.
Also you may as well clean the filter with soap and water and let it dry. Once the filter dries take some fresh oil and drop a couple of drops on the filter and make sure it's has a small amount of oil in it.
Let me know how things go! Good luck!
Posted on Jul 16, 2009
jdlipscomb41
  • 157 Answers
SOURCE: troy bilt 25cc gas backpack blower runs for about 5min then dies
no it sounds as though you have a bad coil
Posted on Sep 18, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the gas;oil ratio for the echo 403T backpack leaf blower.
50 to 1
Posted on Nov 01, 2009
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
130BT Blower can't pull start cord.
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Nov 22, 2015 | Husqvarna 130bt 130 Bt Gas Powered...
4400watt generator will not start plug fireing and getting gas
As you pull the starter cord do you feel compression? If not piston,or rings or cylinder or valves defective.
May 13, 2014 | Homelite Consumer Products Backpack...
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
I used straight gasoline in my husqvarna backpack blower and it will not start. Is this fixable?
Hello Kelly. I don't think this connection will have good news. When gas is used in these gas/oil engins straight it usually burns them up . If you can pull the cord you can check for compression, by pulling out the spark plug and putting your finger over the plug hole. Youwill either not be able to pull cord, or piston will be stuck in cylinder. GOOD LUCK.
Oct 11, 2011 | Husqvarna Garden
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
The start cord on the leaf blower won't pull out more than a few inches. Why is this?
pull your spasrk plug out and see if it pulls over then, cylinder might be fullof gas causing hydro lock condition,if so pullit till cylinder dries out then re-install plug and try starting. if all is good check your fuel cap to make sure the vent is working! If it's not venting this causes vacumn that pull fuel out of tank to cylinder after it is shut off...........Good Luck 2StrokeJim
l
May 23, 2011 | Troy bilt 4cycle Backpack Blower 32cc
Pull cord not catching
If you remove the cover, there is a metal arm that pops out when you pull. The arm is probably rust or just stuck. Spray it with lube and work it around so it loosens up.
Apr 17, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Echo Pb - 413t Backpack Blower Logo
219 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
