Question about Pioneer Televison & Video
MY PIONEER dvd-RW dvr- 212d drive will not autorun. When I put a disk in the drive i have tto maually open the disk aand then have to double click on the autorun file load the program. Is this normal anf if not how can I fix it, Thanks Russ
    Sergeant:
    Champion:
  • 347 Answers
Hello russredM,
Here you can find a detailed step by step about how to enable or disable the autorun option in your DVD
http://autorun.moonvalley.com/enable.htm
Posted on Jun 18, 2008
    Sergeant:
  • 243 Answers
Enable/Disable Autorun How To Enable/Disable Autorun (Windows 95/98/Me)
  1. Access the System Properties Dialog. Using Control Panel: My Computer: Properties or Explorer: My Computer: Properties.
  2. Select the Device Manager tab.
  3. Select the CD-ROM folder.
  4. Select the entry for your CD-ROM drive.
  5. Select Properties.
  6. Select the Settings tab.
  7. Turn on or off the Auto insert notification option.
  8. Select OK.
  9. Select OK
How To Enable/Disable Autorun (Windows NT/2000)
  1. Start RegEdit (regedt32.exe).
  2. Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services/Cdrom.
  3. Edit the Autorun value to '1' to enable autorn, and '0' to disable autorun.
  4. Close RegEdit
How To Enable/Disable Autorun (Windows XP)
  1. Open Windows Explorer by pressing the Windows + "e" key.
  2. Right-click the desired CD-ROM and select Properties from the menu.
  3. Select the AutoPlay tab.
  4. Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
  5. Select OK.
How To Enable Autorun for Other Removable Media Autorun can be enabled or disabled for all Removable media types, such as a floppy or Zip disk. Windows systems are configured to enable CD Notification, other removable media are by default disabled.
The System Properties User interface only exposes the CD Enable or Disable selection. The setting reflected in this dialog makes an entry in the System Registry. It is in this same location that other media types are configured.
Notes:
  1. Modifiying the Registry is not for the inexperienced user. Anyone will tell you, be VERY careful.
  2. The modifications made in this case use Hex not Decimal numbers. If you are unfamiliar with the Registry or the characteristics of base numbering and Hex, studying these topics prior to making these modifications is advisable.
To Modify these Registry Settings, Use Regedit and navigate to the following Key:
HKEY_CURRENT_USER
Software
Microsoft
Windows
CurrentVersion
Policies
Explorer
"NoDriveTypeAutoRun"
The default value for the setting is 95 0 0 0. Change the first byte to 91. Restart the computer to make the new setting take effect. You may have to right-click on the floppy and choose AutoPlay from the menu to see the AutoPlay behavior.
  • Nathan Ayers
    Nathan Ayers Jun 18, 2008
    just follow the steps i have provided and you will be fine.
  • 4,472 Answers
Yes this is only a setting in windows I will walk you through it step by step.
Thanks,
Lee
  • Lee A.
    Lee A. Jun 18, 2008
    Before attempting the below instructions ensure the CD that may
    not be AutoPlaying is capable of doing this. Not all CDs are capable
    of being auto played. CDs that are AutoPlay data CD's will have a
    "autorun.inf" file in the root
    directory of the CD.
    AutoPlay on a data CD (Windows 95, 98, and ME)
    ENABLING
    1. Click
      Start, Settings,
      Control
      Panel
      , and
      double-click the
      System
      icon
    2. Open
      Device
      Manager
    3. Click the + next to
      CD-ROM and double-click the currently installed CD-ROM drive.
    4. In the
      CD-ROM properties click the Settings Tab and verify that there is a
      check within the Auto Insert Notification section. If there is no
      check in this box, place a check into the box, then click Ok and restart
      the computer.
    Enabling AutoPlay on a data CD (Windows
    NT and 2000)
    Note: Performing the below steps
    will require that you edit the system registry.
    Make sure you are aware of the issues that could occur if the
    incorrect registry entry is made.
    1. Click
      Start, Run,
      type regedit and press enter.
    2. In the Registry Editor open the below registry
      key:
      HKEY_LOCAL_MACHINE\
      System\
      CurrentControlSet\
      Services\
      Cdrom\
    3. When in the Cdrom folder change the Autorun from a '0' to
      a '1'
    4. Close the Registry Editor.
    Enabling AutoPlay on a data and audio CD
    (Windows XP)
    1. Open
      My Computer or
      Explorer
    2. Highlight
      the CD-ROM
      drive,
      right-click the CD-ROM drive
      and click
      properties.
    3. Click the AutoPlay tab.
      Within this section you will be able to specify all Windows
      AutoPlay features.
    Enabling AutoPlay on an audio CD (Windows
    98, ME, and 2000)
    1. Click Start, Programs,
      Windows Explorer
    2. Within
      Explorer
      click View and then Folder Options.
    3. Click the File Types tab and locate
      "CD
      Audio Track" category within the list of available file types.
    4. Highlight
      "CD Audio Track" and click Edit or Advanced.
    5. In the Actions category double-click
      the option listed Play; if this is not listed, see the next paragraph.
    6. If you wish to use the default
      Windows CD player ensure that within the "Application used to perform the action"
      section is c:\windows\cdplayer.exe
      -play
    7. Once set make sure this action
      is the Default.
    If Play was not an option listed when following the above
    steps, in the "Edit File Type" window click New, for the Action
    type Play, for the Application used to perform this action
    type c:\windows\cdplayer.exe -play .
    Note: The above steps
    are for setting audio CDs to be played with the default
    Microsoft Windows CD player. If you have a different CD player
    you want to use you will need to edit the play to point to the
    program you wish to play your CDs.
    95)
    1. Open My
      Computer click View, Options, File Types
    2. Highlight
      the "Audio CD"
      section and click edit.
    3. Double-click the Play option and ensure that
      the Application used to perform this action is cdplayer /play.
      If this appears to be set properly, click ok and ensure that the play
      is bold indicating that it is set as the default action.
    Note: The above steps are
    for setting audio CDs to be played with the default Microsoft
    Windows CD player. If you have a different CD player you want to
    use you will need to edit the play to point to the program you
  • Lee A.
    Lee A. Jun 19, 2008
    Still waiting to hear back from you if you need anything else please let me know. If I don't hear back I will assume you got everything you needed and my solution was more then helpful. If you do get a chance and could accept and rate accordingly it would be greatly appreciated.
    Thank you,
    lee
    Guru:
  • 1,894 Answers
Then it means the link file for auto run is missing.
  • 1 more comment
  • dewan nafees ahmed Jun 18, 2008
    Go to My Computer.
    Right click on DVD icon.
    Click Properties.
    And go to autoplay.
    Try downloading Tweak UI from Microsoft (free) and checking your Autoplay settings are correct.
    go to ur registry... HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\CDRom
    and value was set to 0, so manually set it to 1 and it must work.
My drive is listed as DVD-RW-DVR-lllD, but when I put a DVD disk into it, it changes automatic to CD-RW Drive E. How do I keep it as a DVD burner?
Try burning a disk, and taking the burnt disk to another computer, to see if the other computer recognizes the media as being a DVD disk.
Oct 28, 2009 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Pioneer dvd rw dvr-k16a driver of toshiba laptop not functioning
this shows that your DVD RW is out of order and the only solution is to replace it with the new one.
dont forget to vote
Oct 10, 2009 | Pioneer DVR-K16 Burner
My Pioneer 212d DVR read cd not dvd.
have you tried other dvd's? maybe the brand you are using is bad. if you get a cheap brand of dvd's like off brand then yout tend to get coasters. and tend to get more of them the cheaper they are.
Sep 29, 2009 | Pioneer DVR-212D Burner
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
DVD+RW compatibility
your dvd only writes to dvd-r and dvd-rw, but writes to both cdr + and - r/rw. To confirm it go into nero tools and nero info tools and all the ticks in the boxes are what your drive supports
Apr 17, 2007 | Pioneer (DVR-106D) DVD±RW Burner
Televison & Video Logo
128 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
