Question about Toto S300 Washlet RND Seat COTTON WHITE SW55301
I am installing a Toto S-300 Washlet on a Toto enlongated toilet. My issue is the baseplate position. The baseplate is preassembled with screws inside rubber mountings that are inserted into the toilet seat mounting holes. The instructions aren't clear about how far one is to inset the rubber mountings into the holes. There are two bumps on each of the rubber mountings. Does one insert the rubber mountings so that just the bottom bump goies through the mounting hole, so that the baseplate stands proud of the toilet? Or, does one insert both of the bumps all the way into the mounting holes, so that the baseplate is more or less flush with the tolet?
  • 2,841 Answers
There must be a gap of 1/16" or more between the toilet tank and rear of the paper template. For an elongated toilet the bolt on the mounting plate should be toward the front of the slot on the base plate. The base plate must be tightened down until it touches the toilet and there is no gap.
Posted on Nov 13, 2010
I need a Base Plate Template for my toto washlet c100
Wow I need one of those. Never even seen one before. Found a site that has spares luv.
Washlet C110
Nov 03, 2011 | Home
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
Had a new commode installed and now the washlet toto won't work. what can I do to trouble shoot it
check the GFCI outlet (ground fault circiut interupt) that the commode is plugged into there is two button on the outlet one is test and the other is the rest try pushing the rest button. If it kicks back off or doesnt take care of the problem call the installer.
Dec 24, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
The toilet seat on my TOTO toilet has come off. Has something broken that I can repair or do I have to buy a new seat?
are you sure it is broken or the screw has come loose check it out again does not break very easily
Sep 26, 2009 | Toto Washlet S400 for Power Gravity...
How does one replace the seat on a Toto Washlet model SW824?
two screw if you look in frent botim of tank that you flush normally plastic open and the seat will come off and you put back the new one the same way back
Aug 05, 2009 | Toto Washlet S400 for Power Gravity...
Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Toto S300 Washlet RND Seat COTTON WHITE SW55301 Logo
62 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
