Question about JVC GR-DX77E Mini DV Digital Camcorder
Play back poor now Camcorder does not record - JVC GR-DX77E Mini DV Digital Camcorder
    Guru:
  • 2,178 Answers
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
Posted on Nov 12, 2010
  • 8 Answers
SOURCE: Sony camcorder
you might want to try this place alamocameraservice.com
Posted on Jan 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
Lompanow
  • 57 Answers
SOURCE: hi my sony dcr-hc18e camcorder plays back but doesnt record
Unfortunately you're going to need to get some repairs done to your device, the reasoning behind the black screen on recording mode is that one of the many pieces responsible for bringing the image from start to finish has become mis-aligned.
It's either going to be the CCD sensor that has shifted or one of the lenses is slightly off angle and is sending the image off into a wall on the inside of the camcorder.
Estimated repair cost is going to be in the range of $200 USD.
Best of luck with this!
Posted on Dec 09, 2009
c1apton15
  • 3400 Answers
SOURCE: I can't play back tapes
It's not your recorder, it's the different formats other cams are using. Your's is one of the higher end units vs the "Ebay specials"
Posted on Jan 02, 2011
Testimonial: "Thank you very much!"
  • 27 Answers
SOURCE: Hi, I have a sony
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Posted on Feb 20, 2011
Why is my sunsung camcorder having problems when playing back tapes?
Try using a recording head cleaner. This looks like a tape but cleans the heads. Follow the instructions.
Aug 15, 2014 | Samsung SMX Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
JVC Camcorder- Recording Problems
i have a jvc GR.D20EK and am having problems when recording, it plays back but i cannot record it will play recorded tapes can anyone help me. Thanx
Apr 07, 2009 | JVC Video Cameras
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Wont play on computer or dvd player
Disc must be finalized before it can be played back on DVD player or DVD recorder.
Aug 25, 2007 | Hitachi DZ-GX3100A DVD Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
JVC GR-DX77E Mini DV Digital Camcorder Logo
194 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
