Question about HP Officejet 4315v All-In-One InkJet Printer
I have an HP Officejet 4315v all in one printer.How can i set it to print in default instead of fax
  • HP Master
  • 1,679 Answers
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Posted on Nov 12, 2010
HP Officejet 4622 after installing I only see the printer on fax not under the printer list
you may have to reinstall printer from cd. Both Printer and fax should show. check settings on printer for functions.
Nov 06, 2013 | HP Officejet 4315v All-In-One InkJet...
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
My printer is "offline". kathrynmcclellan@att.net
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 16, 2010 | HP Officejet 4315v All-In-One InkJet...
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
4315v Officejet all in one not faxing
Perhaps it is not connected to the phone line? Maybe you don't have a fax number set up? If your phone is having issues, it will affect this.
Apr 20, 2010 | HP Officejet 4315v All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4315v All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
