Question about Euro-Pro 0.7 Cu. Ft. Convection Toaster Oven
Why does my Model #T0289N2 date code 4607, Convection Toaster over not heat? It blows cool air in the oven. The coils do no heat, not even warm.
SOURCE: Euro-Pro convection toaster oven, model T0160
http://dl.owneriq.net/e/ecba07e9-a522-4904-cd42-600c140e33ff.pdf
MANUAL
Posted on Nov 08, 2008
  • 4 Answers
Here is the 7 page Owner's Manual:
http://www.euro-pro.com/europro/manuals/TO160.pdf
Posted on Dec 11, 2008
crappy_focus
  • 51 Answers
SOURCE: Need manual for Euro-Pro professional Model K5345B combo oven
here is a link to allow you to download the manual. go to this link and choose get manual.
hope that helps:)
Posted on Feb 11, 2009
cactus bob
  • 267 Answers
SOURCE: sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Posted on Feb 25, 2009
cactus bob
  • 267 Answers
SOURCE: Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 31, 2009
My toaster oven has no power
This can be due to three reasons:
1. It can be fault in the wire to the oven, if the plug is faulty or the wire has opened out.
2. Secondly if the switch to activate the heating coil is bad it will not connect the power to the coil
3. Finally if the coil is OPEN , then it can be checked using a multimeter as also the wire connection to the heating coil.
Aug 25, 2011 | Black & Decker CTO649 Toaster Oven with...
The toaster (upper) part of our 4-slice toaster oven model 6067 suddenly stopped working after several months of using it consistently. Will return it to Target but hoping it's an easy fix. We kind of like...
Hi there. I just repaired mine. The wire connected to left side (as you are looking at the front of the toaster) of the front top heating coil had come off. I replaced all four of the crimps going to each side of each of the top two heating coils as well as the wire going between the front and back coils on the left side. Make sure that you use HIGH TEMP crimps and HIGH TEMP wire. I had the crimps and purchased the wire from a ma and pa repair shop here in my town1_24_2012_10_47_09_pm.jpg
Jan 01, 2011 | Sunbeam 6067 Toaster Oven with Convection...
Oven does not cook at temperature set at. 2 hrs.
Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Sunbeam toaster oven upper heating coil not working
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
hope that helps:)
Feb 09, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Krups 296 Toaster Oven will not heat
Fusible link inside the unit is probably broken.
Nov 24, 2008 | Krups 296 ProChef Ultra 1500 Watts Toaster...
Euro-Pro 0.7 Cu. Ft. Convection Toaster Oven Logo
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
