Question about HP OfficeJet 6110 All-In-One InkJet Printer
Constant scanner failure error won't allow printing
  • HP Master
  • 7,733 Answers
Won't print System Error E100 in window
E100 means a beam detect failure of the laser that "writes" the image to the drum. There are 3 logical causes. The laser scanner unit has failed.Next down the list is the DC controller has failed.Last, the Image Processing Board has failed. The code indicates the laser is not coming on which would lead you believe that it would be the primary cause.The laser unit has a detector inside that looks for the laser and reports success or failure to the image processing board.The DC controller is resposible for turning on the laser and its ouput. That's why there are at least 3 variables.
Jul 09, 2011 | Canon imageRUNNER 2010F Copier
Phaser 6180MFP has error code 133-290 how to correct, and what is it.
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Oct 04, 2010 | Xerox 6180MFP/N Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Error msg says scanner failure.
ensure the printer was correctly enstalled, check all connections ensure a tight fit. if it is connected to a network make sure the network cable is plugged in and blinking green
Nov 03, 2009 | HP Photosmart C6100 All-In-One Printer
Scan failure
try scanning from your printer/scanner program on the computer. My scanner will not work stand alone, but does work this way
May 11, 2009 | Office Equipment & Supplies
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer cartridge error,then scanner failure...
my printer is say "instrucciones para alinear cartuchos de imperion"
Dec 21, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
134 people viewed this question
Seeker5211
Seeker5211
