Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I HAVE A HOTPOINT BWD129 AND CANNOT GET ANY POWER NO LIGHTS AT ALL BUT PLUGGED IN AND POWER FROM SOCKET FINE .ANY IDEAS
SOURCE: Hotpoint bwd129 quickwash and 1200/600 lights are
hi i worked for hotpoint for 25 yrs and the problem is nearly always with the pcb they are at best ****
Posted on Jun 02, 2010
huuum
  • 750 Answers
SOURCE: Hotpoint BWD129 - Wash temperature too high
Hello
Welcome to Fixya
My name is Huum,
Water temperature switch
The water temperature switch directs power to the valve. If there is no power getting to the valve, check the switch according to the wiring diagram for your machine.
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 23, 2008
SOURCE: There is a series of
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Posted on Jan 31, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Oct 15, 2013 | Hotpoint Ultima WF860 Front Load Washer
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
WD440 - no lights coming on
Could be door interlock switch/ or mains switch.if you have multimeter you can check this beware of mains voltage hazard!!
Nov 11, 2009 | Washing Machines
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd129 how can i open the filter at
Thanks.
Jul 21, 2009 | Washing Machines
Oct 05, 2008 | Washing Machines
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Apr 03, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
