Question about Ken A Vision T2600C Microscope
I want light to shine down onto specimen. The light is plugged into power but I have to hold it over the specimen. Where do you attach it
  • 36 Answers
I am attaching a link to an instruction manual.
You can clearly see where the light is meant to mount.
www.ken-a-vision.com/pdf/INS-SC5.pdf
Posted on Dec 24, 2010
How do some scorpions glow when light shines on it?
Do scorpions glow? Yes. That's an easy question to answer. It's a bit more difficult to pin down what exactly causes them to glow. In fact, scientists are still working on finding a firm answer to that question.
What scientists do know is that something in the scorpions' exoskeletons cause them to glow. Scorpions, along with other arthropods and insects, have an outer layer called a "cuticle." Unlike the cuticles on your fingers, which are made of hard or dead skin, the cuticle on a scorpion is a part of its exoskeleton. This cuticle has a thin section called the "hyaline layer." The hyaline layer is what reacts to ultraviolet (UV) light, such as black light or moonlight, and causes the scorpion's body to glow.
The hyaline layer is really strong and truly stands up to the tests of time. In fact, scientists have found that even fossilized scorpions glow under UV light. Additionally, when scientists preserve scorpion specimens in liquid-filled jars, the hyaline layer can make the liquid glow! Crazy, right?
While observing scorpions, scientists have noticed that the creatures don't glow immediately after molting. Rather, the cuticles have to harden completely before they shine blue-green in the starlight. But scientists still don't know if the glowing material comes from a chemical reaction in the hardening process, or if the scorpions actually secrete the glowing substance.
May 14, 2017 | Cars & Trucks
Microscope will not focus on high power cloudy
Since there's only a very small amount of light reaching the lens system of microscopes when on high powers, A special technique (called >>>oil immersion
Not using this technique must be the cause of the problem you are experiencing.
eHow will guide you through the exact procedure of using the oil immersion technique: http://www.ehow.com/how_8431358_focus-high-power-objective-microscope.html
Good luck in exploring the micro world!
Jul 09, 2011 | Zeiss Microscope
What is the function and the purpose of the parts of the microscope ?
Starting at the bottom of the Compound Microscope scope working up: The base of the scope houses the illumination system and the field lens. It also provides weighted stablility.
The field lens is where the light comes out of the base. This lens focuses the light from the bulb directly into the substage condenser.
The arm of the scope supports the rest of the scope.
Directly above the field condenser is the substage condenser. The substage condenser collects the light and condenses it further into a more concentrated beam of light. With the substage condenser you can control the amount of light and to some degree the defraction of light. This is helpful in adjusting the "contrast" in the image.
Working up, you find the "stage" which is a platform to support the specimen. The stage may or may not have a specimen holder and a set of specimen holder control knobs.
The magnifying lenses are called the objectives. They look like barrels pointing down at the stage. These are usually marked 4x, 10x, 40x, and 100x. These magnifications are further multiplied by the power of the eyepieces which are usually 10x. So, when using the 4x you are actually seeing the specimen at 40x and when you are using the 10x objective you are actually seeing the specimen at 100x and so on. The 4x is used to "scan" the specimen so that you can find the most interesting area and then focus in further on that region. It is very hard to find exactly what you want to focus in on starting with the higher magnifications. Always start with the low magnifications, 4x or 10x.
The objective lenses are mounted on a rotating turret for easy selection.
Moving on up the scope is the head. It is comprised of the eye tube and the eyepiece. If you have two eyepieces your scope is referred to as a "Binocular Compound Microscope". If you have only one eyepiece, your scope is a "Monocular Compound Microscope".
Sep 27, 2010 | C And A Scientific IExplore Scope
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Screen lights up when charging, but wont power on
Hi you have to hold the button down for few seconds if this dose not work leave to charge for longer,if you still have a problem your batt may not be holding charge
Jan 13, 2009 | LG KM500 Cellular Phone - Unlocked
Wont go onto standby.
When you press power ( on the wii itself), keep holding the power button for 4-5 second and it should go to standby mode, front led shines RED. :)
Oct 06, 2008 | Nintendo Wii Console
Timing
You need to disconnect the control wire from the computer so the distributor falls back to base timing. It should be a grey plug over by the blower box. Looks weird, just a wire going to a plug and back out; the plug is just a bridge to break the connection. Timing should be set at 10° BTDC.
Oct 04, 2008 | 1989 Ford Bronco
No power
I also had this problem - and by accident I found that the battery just wasn't pressed down enough onto the contacts when the door was shut.  I now use a little bit of cardboard on top of the battery - then I close the door - now it works fine
Jun 26, 2008 | Panasonic Lumix DMC-FX50 Digital Camera
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Ken A Vision T2600C Microscope Logo
108 people viewed this question
Top Ken A Vision Science & Laboratory Experts
William McMath
ray gallant
Are you a Ken A Vision Science and Laboratory Expert? Answer questions, earn points and help others
