Question about Panasonic KX-TG1033S Cordless Phone
How do you set up the panasonic 6.0 plus. I've had it pulged in for 1 hour and it still says "No link reconnect base or AC adaptor".
5 Suggested Answers
  • 514 Answers
SOURCE: push the talk button and it said no link to base reconnect ac ada
go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Posted on Feb 22, 2009
Coleman37
  • 337 Answers
SOURCE: One of the phones gives the message
If other phones are working with this base, then you may need to register the phone with the base. You will have to check your manual for how to do this. Some phones have it on their menu and some do it by simply placing the phone in the base unit. I'm not sure what model you have or how old your system is. Hope this helps. Good luck!
Posted on Mar 02, 2010
taran_2005
  • 10515 Answers
SOURCE: KEEPS SAYING NO LINK TO BASE - RECONNECT MAIN
ry this.
Registering a handset to a base unit
1 Base unit:
Press and hold {LOCATOR} for 4 seconds until the registration tone
sounds.
  • If all registered handsets start ringing, press the same button to stop. Then repeat this step.
  • The next step should be completed within 90 seconds.
2 Handset:
Press {OK}, then wait until a long beep sounds.
Note:
  • While registering, "Base registering" is displayed on all
registered handsets.
If the problem does not resolve, check that the AC cord is seated fully at the base of the unit and that the handset is fully charged.Use a different fuse for the phone to eliminate blown fuse issue which could be quite common.
If the problem persists, you need to send the phone for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 19, 2010
SOURCE: "No link to base, reconnect
Disconnect the AC adaptor from the unit, wait for a minute, then reconnect. The plug may have become loose over time, or not fully inserted. If that does not work, try reregistering the handset, another handset may have deregistered this handset.Initially, the displayed message indicates that the base is not receiving power. Verify that the base is lighted up / powered on.Try a full hard reset on the Panasonic KX-TG9333T by disconnecting the power and telephone line connection to the base and remove the batteries of the 3 handsets. Allow unpowered, disconnected condition for an extended period of time (6-8 hours). The idea is to force the system to revert back to factory defaults.Reconnect the KX-TG9333T and the batteries to the handset. Recharge if necessary. Go through the initial set-up procedures.
Posted on Aug 08, 2011
The antennas on both 1,2 are blinking how can i get them to stop and to connect to my phone line,and plus they say that no link.reconnect base ac adaptor? And how to reset them to work again?
When both handsets have the antenna symbols blinking the base set is not working. So check that part. It has nothing to do with the phone line, because the connection between base station and handset should also work without the line connected. Check the power supply of the base station or its cable. When you are 100% sure the power supply is giving the correct voltage and enoug current I'm affraid the base station is defect.
Mar 26, 2015 | Lands Phones
I have a panasonic cordless fonr model number- kx-tg2521e and it has stopped working it says no link to base. reconnect ac adaptor can you help plz
sounds like battery is flat. Put phone on main unit and make sure the main units power cord is plugged in and turned on.
Aug 24, 2011 | Panasonic Lands Phones
Says No Link...Reconnect base AC Adapter
Disconnect the AC adapter from the unit, wait for 5 seconds, then reconnect. The plug may have become loose over time or not be fully inserted. If that does not work, try re- registering the handset.
Mar 06, 2011 | Panasonic KXTG4011 Cordless Phone
Push the talk button and it said no link to base reconnect ac ada
Feb 16, 2009 | Panasonic KX-TG1033S Cordless Phone
Cordless phones display "No link to base.Move closer to base", when an attempt is made to make a call.
Used online phone manual/troubleshooting section to resolve issue. Disconnected AC Adaptor from electric source and reconnect to reset. Problem solved.
Feb 23, 2008 | Lands Phones
STILL SAYS "PLEASE REGISTER"
I think this may be the answer. With multiple handsets reading "Please register" and a "working" base station (w ith dial tone). If you bring the remote units to the base station and place them on hte base, they will register and stay registered after you return them to the remote base. It doesn't say this anywhere in the instructions as it gives you the impression the remotes will register from their own base.
Jan 04, 2008 | GE 25932 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
902 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
