Question about Jabra BT250 Consumer Headset
JABRA BT250V Hearing Problem
I have a JABRA BT250V and its pairing with my iPhone great but I can not hear anything through the device. Can someone help?
  • 2 more comments
  • Anonymous Nov 12, 2008
    I don't hear anything...
  • grill-n-go Nov 26, 2008
    i have the same problem with an 8320
  • micklers Dec 29, 2008
    I can hear fine when I'm calling someone but when someone calls me I hear nothing! Very strange. Was working OK yesterday, today, not working. It's paired with a 3G iPhone. Any ideas?
  • joe_x1 Jan 23, 2009
    I have the same problem. Have you found a solution?
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Posted on Jul 22, 2008
  • bernadett597
    bernadett597 Aug 26, 2012
    i also cant hear it it says its coneected but i cant hear anything
How can I pair my resound hearing aid with my iPhone Bluetooth?
Your hearing aid must be blue tooth compatible or you must have a streamer (usually designed to wear on a lanyard) that will connect to your Bluetooth on the iPhone.
First make sure your hearing aids or streamer is turned on.
Go to the Settings icon on your iPhone and click on it. Scroll down to Bluetooth and make sure it is turned to On, then click on it.
You will see a list of Devices that your iPhone senses in the vicinity. Your hearing aid or streamer should be recognized there.
If it is not, then turn the hearing aids or streamer off and and back on again and it should show up. Click on the device under My Devices. If it asks your for a pairing code, 0000 is usually the default. It might also be 1234.
That should do it for you. Enjoy!
Sep 10, 2017 | Cell Phones
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Oct 11, 2013 | Jabra Cruiser InCar Speakerphone Black
What are the advantages of the Jabra drive over the jabra freeway or tour?
The Jabra Drive is superior because it can be paired with two devices simultaneously. It also offers special noise cancellation technology, so the person on the phone will not be distracted by hearing the low murmur hums of your car
Feb 13, 2013 | Car Audio & Video
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 15, 2010 | Jabra Stone Bluetooth Headset
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    BT250v vibrating after picking up the call
    Check Jabra website for manual.
    It is a simple hold volumne button up or down when switching on or off to disable /enable it
    Apr 21, 2008 | Jabra BT250 Consumer Headset
    Connecting bluetooth headset to ps3
    You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
    Sep 25, 2007 | Video Game Consoles & Games
    No sound
    Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
    Jabra: Turn off the 250
    Phone: Delete the BT connection to the Jabra (in BT settings)
    Phone: Switch off BT
    Phone: Turned off the phone (I've even removed the battery)
    Phone: Turned on the phone
    Phone: Switch on BT
    Jabra: Turn on the 250 for detection
    Phone: Look for audio devices
    Phone: Connect to Jabra
    Problem fixed!
    Sep 02, 2007 | Jabra BT250 Consumer Headset
    Jabra BT250 Consumer Headset Logo
    1,036 people viewed this question
    Top Jabra Radio Communications Experts
    TO Lady
    Greg Cann
    Greg Cann
    Michael Vincent Cruz
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
