Question about Danco Faucet Cartridge
In a Danco 3Z-6HC kit there is a white plastic sleeve. Where does this sleeve go?
Valley 3Z-6H/C
Put the large part of the spring into the plastic or rubber washer first, then insert into faucet. I use a little of petrolem jelly for easy instlation.
Dec 22, 2013 | Danco Faucet Cartridge
3z-6h/c
change cold cartridge call danco if you can
Feb 10, 2013 | Danco Faucet Cartridge
Re: danco universal tub spout I cannot get the white plastic insert (with O ring) to fit over my half inch copper pipe. I have used sandpaper to shine it up, but it appears to be way off. and tapers too...
Apply heat proof plumbers grease on the copper shaft and o ring. Be sure end of copper pipe is reemed. Line it up and apply pressure firmly and twist gently back and forth until it slides on.
Apr 23, 2011 | Danco Home
I have a rebuild kit 124166 price pfister shower diverter valve I replaced the packing and the 3/8 l flat washer and one red o-ring gasket, there is a white plastic gasket that i think goes somewhere (i...
The issue might be the tub diverter spout. Most such do not seal well. It is a matter of jiggling the spout knob. It should seal better with a little experimenting.
Aug 30, 2017 | Danco Home
How do the 3 pieces go together for installation. The 3Z-6H/C?? thanks
first off, put the spring in the faucet big end down. then put the black rubber boot seal in next and push it into place. Then place the Stem in but be sure to line up the notches before you screw it all down. I hope the will help you....
Jan 07, 2011 | Danco Faucet Cartridge
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Apr 06, 2010 | Danco Faucet Cartridge
The toilet sometimes will continue to run after flushing
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
Jul 03, 2009 | Danco 89448A Universal Toilet Tank Lever,...
Danco Faucet Cartridge  Logo
144 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
