Question about Hitachi CMP4201U 42 in. HD-Ready Plasma Television
I have a number of CMP4201U monitors. They all suffer the same problem. They will wake up only for approx. 3 seconds, after mains switch is turned on. Mains switch must be turned off or unplugged for approx. 1 minute or they won't wake up at all. I replaced a power supply in one of these units ... no change. When they do wake up for that short period of time, the screen is lit and correct. This apparently is a common problem, since all of these monitors have eventually failed with the same symptom. Any ideas?
  • 13433 Answers
SOURCE: Hitachi UltraVision 42HDT51 Plasma
Is your tv still under warranty?
Posted on Jul 12, 2008
SOURCE: Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Posted on Jul 24, 2008
SOURCE: The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Posted on Jan 15, 2010
  • 6 Answers
SOURCE: won't turn on
Hi, everyone. Me too have the same problem. TV just stays in red but won't turn to blue. I tried unplugging then wait and restart again, sometimes it will work but lately that trick doesn't work anymore. Then somebody suggested to open the back of the tv (it's not hard... just a lot of screws and a couple of bolts to remove) and clean (vacuum) the exhaust fan. Out of frustration, I did open the back and clean the the fan (has a lot of dust on the blades) and everywhere where there is dust. Just be careful not to touch any part of the printed circuit board with the vacuum nozzle to eliminate the destructive effect of static electricity. Or while you're cleaning it you have to hold the metal frame with your other hand to ground yourself (by the way you have to unplug your tv before you start opening the back). After the cleaning then covering the back, the tv worked... for only a few hours. It did stop working again as soon as I turned it off then on again. Again I opened the back, this time I removed the power supply board ( that's the biggest board and located above where you connect all your wirings). Got myselt a small brush and start brushing and vacuuming the dust out. I don't know if the cleaning did the trick or it was the unplugging of the connectors from the power supply board. All these work did the job... my tv is still working for almost three weeks now. Another thing, when you have a a time warner cable with a dvr box where you can program its remote to power most of your equipment in sequence by pressing the remote power button, I set it so that the tv will be powered up last considering that power can fluctuate everytime a unit starts up specially when they are all connected to the same power/surge protector... tv doesn't like it when the power fluctuates while it is still starting. Hope these helps.... (Hitachi 42HDS69)
Posted on Aug 07, 2010
gregjr_pl1
  • 138 Answers
SOURCE: Model: Hitachi P50a402 plasma TV blinking
Did your already check your H- out section. This happen when your TV at protection mode. Its mean it detect defective parts inside the unit. Isolate the H- out power and open the TV Then check voltage if there's power reading meaning that the H- out section have problem.
Posted on Aug 12, 2011
Motorola mbp10
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(email)
Mark
Motorola Support
Sep 01, 2014 | Motorola Mobility Digital Audio Baby...
Works for three seconds at a time
Its becoz there is no signal from your PC. Check the input of LCD monitor i think there might be problem with that cable! ?Mostly the cable gets weired in long run. so check thoroughly! It might work. Or else you have to repair the LCD!
Dec 22, 2007 | Dell E173FP 17" LCD Monitor
How to read the engine codes without a Nissan CONSULT or scan tool. (Set ECM in Diagnostic Test Mode II) Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds....
there is a screw on side of the ECM. turn screw counter clockwise all the way and monitor dash board/check engine light on and count the number of flashes on dash board. when you are done turn the screw back into original spot.
Sep 04, 2011 | Nissan Maxima Cars & Trucks
Monitor does not want to wake up. Pressing the yellow rest switch the button goes green for less that 3 seconds, then goes yellow.
try unplugging your computer and your monitor for about a minute and turn back on. Then see if it works, Good Luck ;)
Nov 12, 2009 | Dell E177FP LCD Monitor
Screen goes blank after 3/4 seconds Monitor approx.1 year old
I can confirm the number 3 solution. I have fixed a bunch of these now.
Replace capacitor C202, 680uf 25V. It is usually visibly damaged. It should be a low impedance type, often known as "suitable for switch mode power supply".Even yesterday.
Nov 06, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Technics S600 Mk 3 Amplifier suffering cut out afer approx
sounds as if amp is clipping.do you have the gain hi, turn it down.are the amps getting good air.are they drawing alot of power from batt alt...do the big 3.
Sep 04, 2009 | Audio Players & Recorders
Stand by mode
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Nov 28, 2008 | Computers & Internet
Php-x19w keeps switching off after a few minutes
I've just spent ages tracking this one down. In my case it is the protection circuit in the backlight invertor. The tubes are worn out (they are pink when they first come on) and need replacing :((.
If the picture disappears and the blue light in the ON switch stays on, you've probably got the same trouble.
Oct 22, 2008 | Computers & Internet
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Hitachi CMP4201U 42 in. HD-Ready Plasma Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
