Question about Nikon Monarch 6 24 X 50mm Fine Crosshair Riflescope 8427
I was wondering if I can get a red crosshair or a red dot installed on my nikon scope
    President:
  • 2,702 Answers
In short its a "no!" you cant fit an illuminated cross to a normal scope
Posted on Nov 25, 2010
How do you boresight a Barnett Red Dot 3 crossbow scope?
I use a 22 cal rifle laser on mine , the 22 is nearest the same diameter to the bolts I use so I can lay laser right into same bolt bed on frame that bolt normally rests in , then bench rest bow and get into shooting position then adj scope to bring crosshairs/ reddot onto laser dot at white target board , try to adj at distance you'd comfortably take a shot at
Sep 07, 2015 | Optics
Crosshair dont move
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Aug 09, 2012 | Bushnell Banner Rifle Scope 3-9X 50...
Cross hair broken on my B S A mil dot 4-16 x 40 scope will any gun shop be able to repair
Yes, more than likely.
The scope just needs to be disassembled and the crosshair flange repaired or replaced.
A dealer should be able to order the part or at least fit one similar enough to work.
The trick is not to allow any moisture into the scope's internal cavity during the repair.
Mar 06, 2011 | BSA 4-16X40mm Mil-Dot Rifle Scope - ...
I have age 3by9by40ir scope. it has a illuminator red dot in crosshairs .problem is need to use much strength to turn on.any way to fix? scope is brand new. somewhere to send?was achristmas present. use...
I've never had that problem with my scopes, but BSA's customer service department welcomes questions and comments. I bet they'll have some good advice. Here's their contact information:
954-581-2144 (Monday - Friday 8.30am - 5.30pm EST)
BSA Optics, Inc.
3911 SW 47th Ave. Suite 914
Ft. Lauderdale, FL 3331
Jan 22, 2011 | BSA ® Huntsman Series?? 3 - 12x50 Rifle...
How do I aline the finderscope
Telescope manuals recommend that you do this in daylight, by pointing the scope at an object on the horizon and adjusting the finder to match (never point a telescope toward the Sun!). Use the lowest power eyepiece you have (the one with the highest number). Once you have a tree or mountain peak in the center of the main scope's image, you can then adjust the screws around the finder scope to get the crosshairs (or red dot) centered on the same object. It is very difficult to do this job in the dark, especially as objects in the sky are constantly on the move.
Jan 18, 2011 | National Geographic 76AZ (525 x 76mm)...
I can see objects through the finderscope, but cannot see anything through the telescope. What am I doing wrong?
Your finder scope is NOT lined up with the main tube. Get a distant object like the top of a telephone pole into the eyepiece of the main telescope tube.
Without moving the scope adjust the crosshairs or the red dot onto the exact same spot. Now your finder scope is lined up with the main telescope tube.
Dec 27, 2010 | Edu-Science (10166) Telescope
Ihave a nikon scope that I have sent back 3 times It pareflex, can not get set .
Parallax error is something that could be different in 2 people. What might be ok to some, will be a nightmare to others. Most scopes are set to parallax at 100 yards, but if you set up your rifle where it wont move, vice, box, pads, peek through the scope to a target at 50 yards, move your head back and forth, up and down, do the crosshairs move with you? How about 25 yards, 100 yards? where it doesn't move is where it is set, and where you find the most accuracy in your scope. It is not hard to hold steady, once you get the hang of it, instead of moving your head to set the crosshairs, anchor your rifle to your cheek and shoulder and move your rifle to the target. There are volumes of material written about this stuff. . Hope this helps.
Dec 22, 2009 | Nikon Optics
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Sighting in red dot shotgun scope
Load your gun up and when you can shoot it, aim with your new glass(Scope) and lay out a group of three slugs, not buckshot, (i'm assuming your shooting a shotgun). Then use some trial and error to tighten your dot to your grouping. I don't blame you for the confusion, but normally, most scopes set up for this adjustment pattern are moving your target according to the knobs, not your crosshairs or dot. Another option you have is to buy a laser bore sighter. then you can play with adjusting your scope for in the field or wherever with much more comfort when you need to. You can find them online at walmart or almost any sporting goods store these days, yes they save ammo and yeas they save time, but i still shoot to make sure i'm dead on after using mine.
Oct 29, 2007 | Bushnell Sportsman 4x32 Riflescope (4x32...
Nikon Monarch 6  24 X 50mm Fine Crosshair Riflescope  8427 Logo
67 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
