Question about Toshiba Satellite P35-S611 Notebook
How do i reformat my toshiba laptop with windows 7 preinstalled
    Brigadier General:
  • 8,909 Answers
Within drive "D" there is a restore section. Start the laptop and as it is booting, press F8, that will open a menu allowing the startup of a restore programme. This will return your laptop to the factory setting.
Hope this helps.
Posted on Nov 12, 2010
I keep getting a error F3-F100-0004 on my Toshiba lap top L455D-S5976 ....f8,f1, & 0 won't work how can I troubleshoot to fix this error & can I do this without using CD or USB
Hi
If you would power up the unit for the first time then you will see that the Win 7 has been already preinstalled and it's ONLY need to finish the setup process...
This will take some time... however... after the Win 7 installation you can find an preinstalled user manual... most people don't read this and this is a big mistake...
In user manual you can find all the details which you have mention here in the posting
> 1) There is no DVD media with Windows 7 recovery.
There is an HDD recovery option available which allows you to recover the unit without the recovery disk... but you can also create an own recovery disk using the preinstalled tool called Toshiba recovery disk creator!
> 2) During the install process you MUST follow all standard options (no extra partitions) if you want to be able to use the recovery partition on the hard drive every again.
As far as I know Toshiba preinstalled Win 7 is an image and does not allow to change the partitions... you can change this only if you use the Microsoft Win 7 disk and this should be clear...
However, the recovery disk should be created ALWAYS as because there is always an risk that something would go wrong with an HDD or partition...
With reocvery disk you are always on the safe side
May 06, 2017 | Toshiba Computers & Internet
Upgraded W 7 to W 10 & now cannot find Games (Looking for spider solitaire)
You need to download them from windows store as they don't come preinstalled as part of the OS now
Oct 08, 2015 | Toshiba Satellite Computers & Internet
I have the toshiba satellite a35-s1592 and I want to know what preinstalled programs I can delete?
Try a google search for a program called 'pcdecrapifier' it checks for pre-installed software that you may not need. No you can't remove older windows updates, I believe the newer updates build on top of the older ones. Also I use a program called Revo Uninstaller, to remove programs and any left over files and folders and registery files that windows doesn't. Hope this helps.
Nov 11, 2011 | Toshiba Satellite A35-S1592 Notebook
I had to reformat my laptop and i wasnt able to make a backup for my files. how do i put back the pre installed software for my laptop? its a toshiba L645D S4036...and the os i am using now is windows 7...
your laptop should have come with a recovery disk. Pop that in the drive and boot off the CD. it will install the factory os and software that came with your computer. NOTE: THIS WILL ERASE EVERYTHING CURRENTLY ON YOUR HARDDRIVE.
If you do nothave the recovery CD you can obtain one by contacting Toshiba, but this will cost you money.
if you wanted to upgrade to windows 7, you will have to download the drivers from toshiba for your notebook. as far as the programs that came preinstalled on your computer they might or might not work with windows 7. you can always run them in compatibility mode to get it to work (does not always work though)
Mar 02, 2011 | Computers & Internet
I have a new satellite L455D Toshiba running on windows 7. The problem is it cant detect usb drives despite the device manager showing that a usb is plugged in.
THIS PROBLEM IS USUALLY CAUSED MUST TIMES WHEN THE OPERATING SYSTEM IS FAULTY.
TO SOLVE THIS PROBLEM PLS REFORMAT AND RELOAD THE WINDOWS 7 OF YOUR COMPUTER SYSTEM..
PLS REMEMBER TO RATE MEEE
Dec 24, 2010 | Toshiba Satellite L455DS5976 Notebook
Ive lost my password and i cannot log on how do i reformat my toshiba laptop with windows 7 preinstalled
Hey, Here are three methods for you to reset Windows 7 password.
Method one: Logging in Windows 7 with an available adminaccount to recover Win 7 password
Methods two: Creating a password reset disk to recover the Win 7 password, bythis methods, you need create a Windows password reset disk before you havelost or forgotten your Windows admin password.
Method three: Using Windows Password Recovery Basic software to recover Windows 7password.
Nov 14, 2010 | Toshiba Satellite L500 Series Notebook
Mi portatil thoshiba no lee mi sd 4g despues que le puse w7
Hablas ingles? Yo intiendo que usted tienes problemas con su 4gb SanDisk Thumbdrive y su Toshiba laptop despues que puses Windows 7.
Usted tienes dos alternativos. 1. Reforma su SD 4gb Thumbdrive con Windows 7 2. Retorna su Toshiba a Windows XP
------------------------------------------------------------------------------------------- Traducion en ingles:
I understand that your SD 4gb Thumbdrive isn't working with your Toshiba laptop after you upgraded to Windows 7. You have two possible alternatives: 1. reformat your SD 4gb Thumbdrive using Windows 7 to format. 2. Go back to Windows XP, or whatever operating system you were using before the upgrade.
Aug 03, 2010 | SanDisk 4GB microSDHC Memory Card
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Toshiba qsimo notebook f45 with windows vista hanging
Yes it is possible. Jus wipe off vista first.
Get bac @ me!
KJ
Apr 24, 2008 | Computers & Internet
Toshiba Satellite P35-S611 Notebook Logo
231 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
