What is the problem with my dynex 37" flat screen tv? I just recently replaced the backlight inverter board but that didn;t fix the prob. I now turns on but quickly turns to a dark screen again. What is the prob?
  • 5 more comments
  • syoyos5 Nov 13, 2010
    Well the model # is DX-lcd37. As for the rest of the question, I replaced the one inverter board that's on the side of back panel. I think there is another "board" in the middle of the tv but I didn't mess with that yet. Is this also a backlight inverter board? The serial number of my model is E377AZNK2WBYNN I think anyway! I don't know if that helps.
    Well my model is dx-lcd37 and the serial number is E377AZNK2WBYNN I think! I replaced just the one backlight on the side of the back panel. I didn't mess with anything in the middle yet although it looks like there is another board there. Is that the other backlight "board" your talking about?
  • syoyos5 Nov 14, 2010
    Hi again! Just opened the tv again and it definitely doesn't have two backlights. At least not that we can find. I have a pic if you want to see what we are seeing. If you want my opinion I think Dynex put only one in and tried to get away with equiping the insides of this model 37" tv with 32" parts. But I don't know what's wrong in order to fix it. What's the panel in the middle? Is this the power supply? Is that the problem?
  • syoyos5 Nov 15, 2010
    I'm trying to fix my 37" dynex lcd tv. I replace the backlight inverter. It only has one! But it still doesn't show a pic. should I also replace the power supply board? If you look in my past comments you'll see a pic I sent.
    The connection are all good. Is there a voltage check I can do? Some device that checks whether it's receiving the correct voltage? We might have something like that but I'll have to wait til tonight to check.
  • syoyos5 Nov 23, 2010
    So I just got the power supply board and installed and no luck. The backlight still goes off. When I first turn on the I get the "please wait..." message on for no more that a second then the black screen again. But the power light is still green. I don't know what to do! What next?
  • 335 Answers
Disconnect the LCD-Board from the main board and see if the back lights stay on, if they stay on then the LCD board needs to be replaced not the inverters. If the back lights continue to shut down then its the power supply board not supplying the 24 volts needed to drive the inverter boards. In that case your'd need to fix or replace the power board.
http://tvtechwork.webs.com/
Posted on Nov 15, 2010
  • 10,594 Answers
Did you replaced both back light inverter boards in your Dynex 37 inch tv?
What is model number of this tv?
Does power supply board provide correct voltages to back light inverter boards?
Let me know above info to diagnose problem.
Thanks.
Posted on Nov 12, 2010
  • Shahid Electronics
    Shahid Electronics Nov 13, 2010
    Yes, 37 inch and above lcd tv has 2 back light inverter boards, other board should be changed as that board could be cause of problem. Other back light inverter board would be installed at other side of lcd panel. (not in middle of panel)
    Thanks.
    Shahid Electronics Nov 15, 2010
    Middle section contains power supply and main boards and yes, this tv has one back light inverter board. Please check 24V supply at back light inverter board coming from power supply board.
    I did not got any intimation about your updated post (due to little problem in site's email system) so I was not aware of that new post.
    Thanks.
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Recently bought a Dynex flatscreen 32 inch tv and noticed faint lines moving up the screen. Some channels it is really noticable and others not so much. Tried switching out the coax cable cord and that...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem..
Sep 12, 2011 | Dynex Televison & Video
The tv will not show a picture it just gets a sounds. Called the manafaucter and they said it might be the bulb that went out. Recently just bought the television in 2008.
It takes anywhere from 7-15 years for the backlight to go out depending upon use so that is unlikely. It is more likely that you need a new inverter board or the connections to it are loose. See if a small local repair shop can assist you with a quote for repairing a loose inverter or inverter board problem.
May 07, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Picture goes out but sound remains. After restarting picture is back. Recently the picture would not come back after restart. Next day it worked again.
The tv have 1 or 2 long LCD inverter boards are dying.These 1 or 2 long LCD inverter boards help the tv to have a backlight to produce a picture on to the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 LCD long inverter boards for the replacement.
Mar 23, 2011 | Dynex DX-LCD32-09 LCD TV
T.v.powers up, sound but no pic. t.v. is only 3 months old.
Tv have a dead long board call the LCD inverter board.This long LCD inverter board,help to get a backlight to the LCD screen panel,to produced a picture.Tv only 3 months old,take ur warrenty repair,call the Dynex corp. for warrenty repair.
Oct 16, 2010 | Dynex DX-L22-10A 22 in. LCD TV
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
If colors are inverted?can it b fixed
Yes,must replace the backlight video inverter board it dead,need a new board.If the LCD outer screen not damage buy people it self,but if it is than the LCD screen pannel is the prob.not the video backlight video inverter board.
Sep 26, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
