Question about Sony KP-53XBR200 53" Rear Projection Television
The tv looks like the old tvs with the contrast controll how do you adjust a projection tv
    Brigadier General:
  • 8,909 Answers
Exactly as the old TV's. There is three tubes producing the picture and the technology is just the same. If you cannot find your instruction booklet, log onto Sony's web site and download it.
Hope this helps.
Posted on Nov 12, 2010
The best contrast and brightness settings for a toshiba crt floor model tv,model 50A61
Televisions are unlike other consumer electronics products. Their setup and settings have a tremendous effect on how well they perform. The best TV on the market incorrectly setup will almost always look worse than a mediocre TV setup well.
Ideally, you'll get a setup disc to ensure the correct settings, but regardless, it's important to know what each setting actually does.
To get the ultimate performance out of your TV, a full calibration by an ISF Certified technician is your best option. Even if you go that route, it's good to know what the calibrator is adjusting. So here's a quick look at the basic settings every TV has, and what they do.
Please keep in mind, this is only a general guide in what each setting does, and rough idea how to set it. Correctly setting up a television is a completely different article.
Where to start
Nearly all modern TVs have picture modes. These are labeled things like Standard, Cinema, Vivid, and so on. Cinema or Movie is often the most accurate setting, with all the controls set to offer an image close to what a director intended them to look like. Most people aren't used to an accurate image like this, and to them the TV may appear reddish, soft, and possibly dim. Technically, it isn't. Other picture modes like Vivid or Dynamic are programmed to "pop" on a store sales floor with an overenhanced, blue image. Because most people don't change any of their TV's settings, this has resulted in most people thinking a TV should look blue.
The choice is yours, of course, but we here prefer an accurate image and suggest you at least try it for a few days. Once you get used to it, you'll never go back. Check out What's the best picture mode? for more info.
Regardless, all TVs need tweaking to look their best. Here's what the main controls do.
Backlight
Only LCDs have this control (though not all of them). This is a direct control of how bright the image is. Setting this lower will reduce eyestrain, and save a little on electricity. Before you adjust Contrast to make the image brighter, try here first. Check out LED LCD backlights explained for more on this.
Some plasmas have a control that drives the pixels harder, which in some ways acts similar to a backlight control. Samsung's name for this on their plasmas is Cell Light.
Contrast
Sometimes labeled "Picture." This control makes the image brighter...up to a point. Every television has a maximum light output. Once you reach this point, increasing the Contrast control further actually degrades the image. Correctly set, you would see a fluffy cloud in a bright sky. Set too high, you'd see a blotch of white instead. As mentioned above, try setting the overall light output of an LCD with the Backlight control first (if available). Then adjust the Contrast.
Brightness
This controls how dark the dark areas of the image are, again, to a point. Every TV has a minimum light output. Once you reach this point, decreasing the Brightness control starts removing "shadow detail." Correctly set, you'd see all the detail in a black leather jacket at night. Set too low, and it would be a black area on a black area, probably with a head sticking out of it. For more information on how the contrast, brightness and backlight settings interact, check out my article on contrast ratio.
Color
Can be thought of as color saturation. Setting this too high will make everything look cartoony. Setting it too low will make for an expensive black-and-white HDTV.
Tint
Rarely will you need to adjust tint, a vestigial control left over from the CRT "tube" TV days. It gives a green or magenta shade to the image.
Jun 23, 2016 | Toshiba Televison & Video
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
Black and white picture and no color
The video controller adjustment section for color has defaulted to black and white because the circuit board may have been affected by a power surge or power outage. It may be that the Video board needs replacing.
Feb 26, 2014 | Sony Grand WEGA KDF-70XBR950 70" Rear...
How can I adjust the contrast w/o contrast control?
Almost all sets have a brightness and contrast (which is often labeled picture instead) in the main customer menu-----look to see if it changes the picture or not.
If issue is the picture is there but somewhat slow to appear or dim the model indicated uses a lamp which may be the real problem...
Oct 30, 2012 | JVC HD-56G786 56" Rear Projection HDTV
I have a Sony KP53HS10 projection tv, occasionally the picture will move in and out around the edges kind of shrinking and growing as if the focus is adjusting. the screen goes blank and the red led in the...
You have a weak capacitors in the power supply. Your description has enabled me to say this is the solution. We TV techs call this "breathing". You may control some of this with raising the contrast and brightness to see the picture stabilize.You will need a TV tech to correct the power supply. I have not worked on projection TVs for some time. This is a classic problem with a classic fix. Thanks for asking and show all hands of support!
Sep 13, 2011 | Sony KP-53HS10 TV
GE projection tv
CONTRAST ADJUSTMENT IS ON THE FRONT CONTROL ON TV
Apr 05, 2008 | GE 46GW947 46" Rear Projection Television
Rca tv screen went all red. you can still see program
Color wheel controls the color. try replacing then reindexing the color wheel. Let me know if you need further assistance.
Mar 14, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Sony KP-53XBR200 53" Rear Projection Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
