Question about Daewoo Washing Machines
Daewoo DWDG20D1 - error code PFE shown - clothes aren't properly rinsed, drum still full of soap - can anyone advise what the code means?
  • 7 Answers
SOURCE: soapy cloths after wash
first make sure the drain is at the right height(the exit should be about the same height as the main part of the washer) are the clothes spinning? could be a gearcase problem, also your pump might be clogged good luck!!
Posted on Apr 16, 2007
  • 583 Answers
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
check the link: below
http://www.repairclinic.com/0088_11_1.asp
Posted on Mar 12, 2009
heatman101
  • 43501 Answers
SOURCE: didn't rinse properly, the'res more soap left on
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: tub has a sour smell &does not seem to be rinsing soap out of clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
honeymokey
  • 3113 Answers
SOURCE: Washer is not rinsing soap off of clothes after
Do not overload machine. Do not use too much detergent. Do you have enough cold water pressure? Is the water level correct for the load?
Posted on Dec 11, 2010
Soap is not rinsing out of my clothes. It has been getting worse and worse. Even if I use a tiny bit of detergent.
The obvious question is how do you know that it is soap? What washing machine is it? The biggest problem with most washing machines is that people use too much soap to begin with. I would go to a store and get a new t-shirt or something. Run the machine with nothing in it. Then put the shirt in and run it again without adding any soap. When it is done check the shirt for soap. There could be a build up on the inside of the drum.
May 27, 2015 | LG WM Washing Machines
There is still soap foam at the end of the wash
Perhaps a call to a repair service is needed . water inlet valves do fail .
Aug 25, 2017 | Washing Machines
How do I get an lg washer model number wm2301wh into a test mode
The machine tests itself when power is applied, if there is a problem it will indicate the problem via an error code on the display. If you suspect that the machine is not rinsing properly I assume that there are soap suds or residue on the clothes.
This is usually an indication that you're using too much detergent for the clothes you are washing. Try reducing the amount of detergent by half. Then, if the clothes do not appear to be as clean as they should be, increase the amount slightly for each load, until the clothes do get clean.
Sep 09, 2014 | LG Washing Machines
Error code sd
sd means suds, for either the wrong soap was added or just had too much soap. Rinse out washer, you can use a small cap full of oil (like the oil cap) to deactivate the soap. Then rinse out washer again, this should fix or correct this issue.
Good Luck
Aug 04, 2014 | Whirlpool Washing Machines
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 29, 2011 | LG Washing Machines
My top loading washer has an error code of Sd, don't know what that means??
Sd means suds was detected. "Sd" is displayed when the control senses drag on the basket. Too much soap makes the motor work harder causes it to overheat and generally suffer a beating. The wrong soap also triggers this. Also An item of clothing jamming the basket can trigger this warning. The control has a program to remedy it. Filling, rinsing, and rechecking all in the name of making sure yall's clothes ain't got no soap in em. If the control cannot fix the probo after trying a bunch of times, then it declares an error has occurred and everythang comes to a screechin halt.
Cabrio Washer Service Manual
Mar 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
"LE" what's mean?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Thanks for using FixYa - a 4 THUMBS rating is appreciate dof rnaswering your FREE question.
Sep 25, 2010 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
My hotpoint aqualtis smells awful. the smell is coming from the drum. we have taken the pump off and although this smelled it was nowere near as bad as what is coming from the drum.
run a large load with no clothes and no soap. use hot water and a full gallon or more of bleach. do an extra rinse to make sure all the bleach is rinsed out before putting clothes in it again.
Jun 28, 2008 | Hotpoint Washing Machines
Washing Machines Logo
193 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
