Question about Samsung RGSF5330DT Gas Kitchen Range
Hi,i have a samsung range that the control panel for the oven does not come on it is blank,the top of stove works but the oven can not come on cause the display is blank,also there is a button next to the control panel that lights the oven it clicks on but not the display panel what could b wrong
  • 213 Answers
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Posted on Nov 21, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
SOURCE: oven doesn't work. Display F30 code. Gas Range
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Posted on Feb 11, 2010
heatman101
  • 43501 Answers
SOURCE: KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Samsung electric range: clicking sound and interior light flicking on and off.Followed by loud bang-type noise , and all on range went dark.
Hi Cheryl,
this must be a short cut somewhere, and as there is no light on panel or heat to stove top or oven, I would think it is somewhere in the connection box.
Behind the link is a very nice eplanation what can happen with home appliances.
I hope this will help.
Kind regards, Dik
WAIT why would freshly dried clothes smell like an electrical fire
Feb 16, 2018 | Samsung Kitchen Ranges
Rf365pxmw control panel blank
Do you have the black, white, or biscuit colored control panel?
Feb 22, 2013 | Whirlpool RF365 Electric Kitchen Range
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Oven not working
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
You find parts and diagrams here, just enter the correct model number.
Dec 20, 2008 | GE JBP80 Electric Kitchen Range
The touch pad panel on stove is blank
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
Samsung RGSF5330DT Gas Kitchen Range Logo
187 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
