Question about Camelbak BPA Free Better Water Bottle .5L
Camelbak 24oz bottle has become very difficult to drink from through the straw. Do you know why? I've replaced straw and bitevalve and have thoroughly cleaned.
Is it safe to drink bottled water that was left in a car?
That depends on whether the water is the original water which came in the sealed bottle, how long its been in there, how hot it has become and how many times it's been heated. If you left it overnight and it didn't heat up, it's probably OK. If it's been in a hot closed up car all day, pitch it. Another mistake is to reuse the bottle, adding tap water repeatedly and never washing the bottle, allowing germs to grow and grow. Don't do it.
Jul 16, 2017 | Wine & Spirits
Can you get a water bottle with a filter in it?
Camelbak Groove
The Groove holds 600ml of water and has a carbon filter that is partly made of coconut (really) built into the straw, so it instantly turns the stuff from the tap into fresh water, whenever and wherever you are.
27.48, ukbikestore.co.uk
May 06, 2013 | Home
Noise when i drink from my camelbak
Maybe hole inside in the hos drawing air making the nois you hear.
Feb 17, 2013 | Camelbak Eddy Water Bottle w/ Bite Valve &...
Can I store my wine after I've opened it?
Once you've opened bottle of wine, no matter how much you age it, you be able to drink it for 3-5 days since you've opened it and you can never age it again.
Aug 13, 2012 | Furniture
What drinks do i not put in there? is a gatorade 2 ok or a propel?
From my experience you can put any liquid but alcohol and pop in a camel back and not have any problems . Alcohol wil leave a "taste" in the plastic. Any rehydartion drink should be fine as long as you go through proper washing instructions when you have finished. If you take care of your camel back it will last you for years. I've been usung mine for at least 5 years now and still works great
Sep 10, 2011 | Camelbak Rogue Hydration Pack
Rough idling, high pitch whistling sound
Sounds like a vacuum leak. Best way to locate is with a spray bottle and some water. Spray in the area where the known noise is. You will have located your leak when the water sounds like someone drinking soda from the bottom of an empty cup with a straw. Good luck.
Aug 20, 2011 | 1996 Ford Taurus
During a 6 week trek in limestone country, we both noticed extensive white deposits in the tubes which impeded the flow of water. Assuming it was calcium carbonate, I have tried vinegar to dissolve it but...
The deposits may be a fungus that grows in camelbak, and other brands of, hydration systems due to sunlight shining on the wet plastic. It's possible that if you were using water containing lime that the lime has mixed with the fungus. To reduce the growth some systems have a black insulation which covers the drinking tube. There's a cleaning kit you can get which consists of 2 brushes, a narrow one for the tube and a larger one for the main water reservoir, and tablets which disolve or break up the fungus. You can get them at http://www.wiggle.co.uk/camelbak/cycle/hydration-system-spares/?utm_source=google&utm_medium=cpc&utm_term=camelback%20cleaning%20kit&utm_campaign=camelbak&referid=googwig&utm_agroup=Camelbak%20-%20Hydration%20System%20Spares
or if you look on google for "Camelbak cleaning kit" you might find somewhere near you that sells them.
The fungus is not harmful but it does put a taste on the water and doesn't look very nice.
May 20, 2011 | Camelbak 09 Classic Hydration Pk 70
My Camelbak water bottle has gotten very difficult to drink from. I've cleaned the bottle, the straw, and the screw-on lid. I ran a very thin wood skewer up through the lid and it didn't meet any...
Just figured it out while messing around with it a bit! Remove the mouthpiece and you will see a grey rubbery valve underneath. Gently pull the valve upward to open it back up. Replace the mouthpiece and voila!
Nov 05, 2010 | Camelbak BPA Free Better Water Bottle .5L
Munchkin sippy cup - too difficult to sip!!!!
is there a rubber stopper that may be put in wrong try taking it out and putting it in the other way
Apr 03, 2009 | Munchkin Magic Cube - Mozart
Camelbak BPA Free Better Water Bottle .5L Logo
317 people viewed this question
Top Camelbak Home Experts
john h
Tom Chichester
Are you a Camelbak Home Expert? Answer questions, earn points and help others
