Question about Linksys EtherFast Cable/DSL Router
We are networked and increasingly one or more if us is getting the message that our computer cannot find the correct address. One computer is constantly having trouble accessing Outlook. We are using Linksys DSL Etherfast
5 Suggested Answers
florenn
  • 174 Answers
SOURCE: cant get to internet thru linksys etherfast cable/dsl router
i you restart you devices, modem and router...
first turn off the modem and then the router and last will be the computer
second if you will turn the devices on...
first turn on the modem,wait until the dsl light becomes solid
second turn on the router,wait for a minute and
third turn on the computer.
check the wireless settings for your router and save changes
next, try to check wireless connection by disabling the local area connection (LAC)
Posted on Nov 09, 2008
shoran
  • 54 Answers
SOURCE: Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Posted on Jan 15, 2009
RickOz
  • 145 Answers
SOURCE: access violation at 004273c9 in module WMP54Gv4.exe
This is a software issue with the Linksys program. Do you have the original cd? If so, unistall the program and reinstall it.
Posted on Mar 15, 2009
jaye_ellen
  • 591 Answers
SOURCE: My WRT54GC won't let me into the control panel.
If you connect the router (WRT54GC) to your broadband modem does it then allow wireless action? Your router has an Internet address. It is 192.168.1.1, in all probability. Check your manual to be sure. Access to the control panel is through this address. You must log in to the router then set up the Wireless, the SSID (the name you give your network) and any security you set up. I prefer the WEP-PSK[TKIP] as it's easiest. Other things with the router, settings and such, pretty much are set automatically, so once security is set you should be good to go. Good luck !!!
Posted on Nov 11, 2009
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Our Sharp copier MX3501 is sending a message that selected servers cannot be found. How do we correct?
The scan location (i.e. email, ftp, network folder, computer with sharpdesk) can't be found check the address details and make sure they are correct.
If it is a sharpdesk scan then the most likely reason is that the IP address of the computer has changed (DHCP).
If FTP or Email check the address of the server you are sending to.
Your IT or Service provide should be able to help give you the correct addresses and authentication settings for these.
Oct 21, 2010 | Sharp Office Equipment & Supplies
I' ve been trying to login into my facebook account for a week and still no luck. I think my account has been hacked or maybe evn a virus or something that was sent to me by another friend. I have to...
From Facebook:
If the login email address that you normally use to log in to your Facebook account is still associated with your account:
https://ssl.facebook.com/help/contact.php?show_form=hacked_self_recovery
If the login email address listed on your Facebook account has been removed by the another person (i.e., someone has replaced your login email address with one that you do not control):
http://www.facebook.com/help/?page=1024#!/help/contact.php?show_form=hack_login_changed
There are two indications that your login email address has been removed by another person:
  1. Your profile is still visible on the site when you search for it and there is a different login email address listed under Contact Info.
  2. You received an error message when logging in with the correct login email reading: "The email entered does not belong to any account." (You will also receive this error message if you have made a spelling error. Please be sure to check the spelling of your login.)
To solve this issue on your own, please look for an email at your login email address with the subject "Facebook Contact Email Change Notification" and follow the instructions to cancel the email change.
Aug 27, 2010 | Facebook Social Network
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
Limited or no connectivity
When your computer does not get IP address from the router, you get the message " limited or no connectivity ". There might be 2 possible reasons for this . 1) If your wireless network is secured then you are not entering the correct network key. Open the set up page of the router and check the wireless settings of the router .
2 ) Your router is giving the IP address to the rotuer.
Open the set up page of the router and check , the DHCP server is enabled or not ? It should be enabled.
You are entering the corerct network key and DHCP server is enabled, but still getting the same message. Assign a static IP address to the computer.
Click here for more instructions
Mar 29, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have a IBM netvista desktop and a HP Pavillion on my home office work desk. Now I am getting a message that they are sharing the same IP address! What happen to change one of the Ip address to match the...
Do you use both computers in an existing network (same network)?
Are you using both computers in this same network sharing broadband (internet connection in the same networK?)
Mar 16, 2010 | HP Pavillion s7420n PC Desktop
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
Internet fails from dns
To access the internet from a home broadband network you need the router appropriately configured on the WAN or internet service provider (ISP) side and the attached computer to have an appropriate IP Address, Subnet Mask, Default Gateway and DNS addresses assigned to the network adapter.
Based solely on the title you should understand the following the belief here is that the PS3 is missing DNS address(es).
DNS address(es) are IP address(es) for servers that convert names like www.fixya.com into IP addresses to send messages to normally.
Your ISP generally assigns DNS addresses for your use.
How do DNS addresses get into the computer's network adapter configuration where they are needed? There are two ways generally in home networks someone manually puts them into the computer or someone enters them into the router and via a service called DHCP they get placed in computer's network adapters configured to accept information from the DHCP service on the router.
If the heading of this problem is correct the PS3 appears to be complaining because the DNS address(es) have not been configured into the computer or the router by the user as expected by the PS3's network adapter. I have no PS3 experience however I believe this information may help to resolve your issue.
I hope this helps
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Linksys EtherFast Cable/DSL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
