Question about Lionel 40 Watt Transformer Train Set Track 624253
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014 FasTrack 10" Straight Tracks, 1 (6-12020) FasTrack Uncoupling Track, 1 (6 -12029) FasTrack Accessory Activator Pack, 2 terminal tracks, 2 isolated tracks (brakes the same track side) and in between a (6-12027) FasTrack 10" Insulated Track. I have 2 PowerMaxPlus transformers 40W (120V input) what came in my Penn. Flyer and Santa FE sets. At the begining I started by hooking one each of the 2 PowerMaxPlus transformers 40W (120V input) to the system (Transfomers seemed to operate - Lighted Bumper 6-12035 lighted on - the tracks probably had power - BUT NO MOVE) Then I have just made a circle and hooked one of the 2 PowerMaxPlus transformers 40W (120V input) to it, at the beggining just the front light of the engine lighted on - NO MOVE at all-...what happened next ,smoke started coming out from the transformer so I've unplegged it immediately. Then hooked the other transformer to the circle and just the front light of the engine lighted on - NO MOVE at all...- I've tried the other engine and happened exactly the same. No burning transformer this time but still NO MOVE. Ive tried all the possible positions for the engine's switches on/off neutral. Please help
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 38 Answers
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
I have a problem with a Lionel locomotive stopping when going over a switch. I used to use Atlas O and now use Fastrack with the same problem.
I have had the same problem with FasTrack remotes. I noticed a lot of car wheel sparking on the outter rail which is V shaped with the turning entry part of the switch. I put electrical tape oven the approximately 1 1/2 inch part of the switch on the straight away. Problem solved. The problem has a lot to do with where the center pickup roller is relative to the wheels (common side of power).
On another note:
Also found that a problem with the common side connections using the 1.75 and 1.375" fillers. For some odd reason, Lionel quality control??????. The pin to rail connection is loose on all my fillers. I finally, after getting disgusted, removed all 18 fillers and wired (flow soldered) the connections from the pin dot point to the rail foldovers. Virtually all my electrical problems were solved. I also noted that in some cases, especially the 30" rails, the crossover strap is only crimped down. I advise putting a solder blob on all crossover straps in your setup. This will help when there there is a bad common connection in one or more points in the layout.
I have suffered beyond belief using the FasTrack remote switches. The extremes of poor quality control are evident in these Lionel products. I now have two that have intermittent control indicator lights. It is not worth the effort, they are still under warantee, to remove these switches and send to repair. The first repair resulted in a switch I simply threw away.
Jun 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
My 2-8-4 Locomotive stops at the right hand switch and will not reverse. It is the only train of my three that does this
This is a common problem with FasTrack Remotes and Manual switches. It is relative to where the center roller pickup is in relation to the wheels (common connection to outter track rails). Solution is to put electrical tape on the outter rail that forms a V between the turn in and the straight away. This elliminates about 1.5" of track discontinuity. It also eliminates wheel sparking that pits the surface of the outter rail. Wish I had a better solution short of taking the switch apart and doing some rewiring.
Jan 31, 2011 | Lionel Fastrack O36 Manual Right Hand...
I have Lionel Fastrack 048 switch. I extended the controller wire and all of my slices are perfect. The switch operates but the light in the controller does not operate - neither red or green. I checked...
You will need to check continuity of the yellow RSC wire from inside the controller to where it enters the switch connection block. Neither light will work if this wire is broken.
2nd: Lionel quality control is so poor that if that is not the problem, remove the plate from the bottom and make sure the five plugs are firmly in place on the electronic board. Since both green and red do not work it is most likely not the micro switchs but an issue with the circuit board.
Jan 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
I accidentially broke the signal flags off my sons manual switch. The Lionel website is terrible and I can't find any part listing for the switch to order a new piece. Any suggestions?
My son broke his off as well. We had just added the outer loop expansion pack and it was broken within 10 minutes. I found the replacement part on the Lionel website after much difficulty. I plan to buy a replacement to use one day when we have a more permanent track layout. I removed the flag from the other switch for safe keeping while he continues to play with it on the carpet. This is very poor design by Lionel. I think they should include a replacement part with the switch, or at least provide instructions in the manual for ordering a new part. I have wasted several hours today instead of enjoying the train with my son.
6102017094 RED SIG/LVR ASSY-MAN 036 FT SW $4.00
Nov 27, 2010 | Lionel Fastrack O36 Manual Right Hand...
Reconnecting tranformer wires (red & black) to underside of FasTr
The red wire goes to the center terminal, and the black to the outer one.
Jan 04, 2009 | Lionel Cw 80 Transformer
Lionel 40 Watt Transformer Train Set Track 624253 Logo
523 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
