Question about Soleus PH312R03 Air Conditioner
Need owners manual for ph3 - Soleus PH312R03 Air Conditioner
  • 1,711 Answers
You find the manual in the following link
http://www.sylvane.com/images/prodphoto/so1827/ph312r03_manual.pdf
Thank you in advance for you 4 thump up vote
Posted on Nov 13, 2010
Wiring a ge motor 220; has three black wires
That's a 3 phase motor(ph3). And probably a 220v/460v? Or a 110v/220v, BIG difference! You'll need to figure out your supply voltage and wire it accordingly. Normally, if 220/460, all 3 black wires are hot legs, and this is probably what you have, because 110v will normally have higher amperage than what you posted. And if the motor runs backwards, switch any leg with 1 other. Hope this helps!
Aug 19, 2017 | GE Heating & Cooling
I have trac control inside for my lights outside and need to know how to set for lights to come on off.
PDF]2011 Chevrolet Impala Owner Manual
https://www.chevrolet.com/.../Ownership/Manuals.../2011_Impala... Chevroletyou need to see your owner manual .... inside, pull up or push down on the manual ....The exterior lamps control is located .... The vehicle may have a traction.
[PDF]2015 Chevy Silverado 1500 Owner's Manual - Chevrolet
https://www.chevrolet.com/.../Ownership/Manuals.../2015-silvera... ChevroletJun 20, 2014 - 2015 Chevrolet Silverado Owner Manual M. In Brief . ... Exterior Lighting . .... you need to see your owner manual ... d : Traction Control/StabiliTrak® ..... From inside, use the power door ... The driver window mayhave the.
[PDF]2015 Chevy Traverse Owner's Manual - Chevrolet
https://www.chevrolet.com/.../Ownership/Manuals.../2015-travers... ChevroletMar 27, 2014 - 2015 Chevrolet Traverse Owner Manual M. In Brief . ... Exterior Lighting . .... you need to see your owner manual for additional ... t : Traction Control/StabiliTrak® .... From the inside use the door ..... have buttons located on the.
[PDF]2014 Cadillac ATS Owner Manual
https://www.cadillac.com/.../Owners/Manuals.../2014_ATS_Owners... CadillacCadillac ATS Owner Manual (GMNA-Localizing-U.S./Canada/Mexico- ... Exterior Lighting . .... you need to see your owner manual ... d : Traction Control/StabiliTrak® .... From the inside, to lock a rear ..... The vehicle may also have the Front.
Jan 11, 2016 | Cars & Trucks
2012 owner manual for paloris 400 4x4
Owners Manuals - Polaris ATV, Snowmobiles, RANGER ...
www.polaris.com/en-us/company/owners-manual.aspx
Polaris IndustriesDownload Owner's Manuals. Find your specific manual to download by selecting vehicle type, manual type and model year of vehicle below. Vehicle Type.
www.polaris.com/en-us/atv-ranger-rzr/owners-manual
Polaris IndustriesOnline Parts Catalog & Manuals for the Polaris Off Road Vehicles: Four Wheelers, RANGER RZR Side by Side ATVs and UTVs. The Hardest Working Smoothest ...
Oct 28, 2015 | Cars & Trucks
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: http://www.homedepot.com/catalog/pdfimages/d4/d4382c05-2692-4075-a254-fdcdef6dc1fb.pdf . The buttons are the same across the units.
I hope this helps.
Jul 17, 2014 | Soleus Heating & Cooling
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Where is "flipper switch" on model PH3-12R-03?
Try first unplugging the unit for ten minutes, and emptying the water tank. If the error does not clear, then replace water tank flipper. see how that goes
Jun 05, 2014 | Heating & Cooling
My unit keeps pouring water out what does that mean it also keeps saying full how do I make it stop or how do I empty it?
In case you have misplaced your owners manual, I have included a link to one that is almost identical to yours. There are several ways to drain the water collection tank. So, I want you to be able to choose the one that fits your situation the best.
You can download and print the manual for future reference.
http://cache.air-conditioner-home.com/manuals/soleus-ph3-12r-03.pdf
Hope this helps you.
Jul 08, 2011 | Soleus KY-34 Portable Air Conditioner
How can i find the correct connection in three phase wiring during troubleshooting.
three phase only has one way to wire you have ph 1 ph2 and ph3 only don,t change them around ,,
Dec 27, 2010 | Computers & Internet
USB port does not recognise USB hard disk
Hi, you probably need to partition and format the drive, this can be done by removing it from the USB case and connecting it directly to the IDE or Sata connector, but first try using the disc managment system if running windows XP its located in the control panel within the administrative tools button, here is a helpful link that goes into detail about how to do this. link if not using XP google disc managment for your OS and partition and format the drive so windows can detect it.
Thanks
Eric
Aug 02, 2009 | ASUS Pundit-PH3 (PUNDITPH3) Barebone
Soleus PH312R03 Air Conditioner Logo
133 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
