How do you change the lid switch - Washing Machines
    President:
  • 1,937 Answers
See the following for how to release the console and remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=bd565b63d8f8c39014f7aa79d1722163
With the console tilted back, un-plug the switch from the section in the cabinet. You should be able to see where both sections connect to the console and cabinet.
Also, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Posted on Nov 12, 2010
My remote is bad and the button on the door of my 2008 saturn aura xr will not open the trunk
How about a key ?
Luggage Compartment Description and Operation (Sedan)
Rear Compartment Lid Release
The rear compartment lid can be released in one of three ways:
• Inserting the key into the key lock cylinder, if equipped
• Operating the rear compartment lid release switch
• Using the keyless entry fob
To operate rear compartment lid with the rear compartment lid release switch or with the rear compartment release button on the key fob, the gear selector may be in any position, but vehicle speed must equal 0 for the rear compartment lid to release.
When the rear compartment lid release switch is pushed, the rear compartment lid release signal circuit to the body control module (BCM) is grounded. BCM then grounds the coil side of the trunk release relay through the trunk release relay control circuit. With this voltage is applied to the rear compartment lid release actuator, opening the rear compartment.
do you know how to do electrical testing ?
Circuit/System Verification
Ignition ON, observe the scan tool Trunk Release Switch parameter while pressing and releasing the rear compartment lid release switch. The parameter should change between Active and Inactive.
? If the parameter does not change, refer to Trunk Release Switch Malfunction.
Command the trunk release with a scan tool, the rear compartment lid latch should release the trunk lid.
? If the rear compartment lid latch does not release, refer to Rear Compartment Lid Latch Malfunction
You may want to take it to a repair shop .
Mar 13, 2017 | Saturn Cars & Trucks
Why does my lid lock keep flashing?
There is a right lid lock and a left lid lock which did you change? The left lid lock is a lock and the reed switch which tells the machine control the lid is closed and can start the cycle.
May 03, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Changed lid lock switch and won't work
Is the plunger attached to the lid? It is the little prong that goes into the lid switch.
Apr 05, 2014 | Whirlpool WTW4800XQ Washer
Have to slam lid so lid switch will make,where is the lid switch located
The lid switch is here:themobilian_773.jpgTo check it flip up the controls and unplug it's quick connectthemobilian_774.jpgThe connect has 3 wires, a green ground and two other wires, those two other wires go to the switch. Here is a video that show how to replace that lid switch:
I have a manual and some more videos HERE
Thanks for using FixYa
Jan 07, 2011 | Whirlpool LSR5132PQ Top Load Washer
Lid safety switch how to get out to change how to
Remove screws from rear of timer console, pull console forward and hinge it up to expose brass colored clips. Remove these clips and unplug lid switch connector. The cabinet will now hinge forward and you can remove it to access the lid switch.
Sep 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
What is a code E2
kds e2 means lid switch is not being engaged .remove rear top cover .2 phillips screws .3 snap clips use flat blade screw driver to pop cover .look at rear of lid (door) right side plastic arm part of lid snaped off replace lid part xqb5526f.1.3-3 check saftey switch manually over ride switch as a test .if machine spins change lid if switch broken as well change both .switch # xqb550.1.6
Aug 10, 2010 | Avanti Top Load Washer W797
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
