Question about Thermador Ovens
Error code F64 on lower thermador oven. Works for a minute or so then beeps and F64 is showing,
    Champion:
  • Thermador Expert
  • 323 Answers
Most the time I run across the F64 code it is due to the "sail switch" not being activated. I usually remove the bottom grill and lubricate the micro (sail) switch and actuator (the sail) with a zoom oiler (available at most hardware stores). A small drop is all that's needed. Then move the metal rectangular plate (the sail) back and forth to work in the oil. RARELY do I have to adjust the sail (that metal plate) to "catch" the air and activate the micro switch but that too may be necessary.
Posted on Jun 26, 2013
  • 2,382 Answers
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Posted on Nov 12, 2010
What does code F 64 mean for my thermador double oven?
F64 will appear if lower oven air switch does not close. If air
switch does not close the mode is cancelled after about 45 sec-
onds.
Sep 23, 2014 | Thermador SC302T Electric Double Oven
Thermador F64 upper oven
f64 is a code for the lower oven cooling fan.
Jan 22, 2014 | Thermador Ovens
Thermador upper oven F 64
f64 for the lower, f34 for the upper cooling fans.
Jan 22, 2014 | Thermador C302U Electric Double Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
I am getting an F64 error message. what is this trying to tell me?
Welcome to FixYa.
The "F64" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the lower oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F64 error it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
( F64 can also be initiated by a failed "K4" relay on the control board, but that is less likely )
It can be accessed by way of removing that grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Let me know if I can assist you further regarding this issue and I`ll try to be available asap.
Good luck.
Thank you for choosing FixYa today, please take a moment to rate the info provided here for you.
macmarkus :)
Aug 03, 2010 | Thermador SEC302 Electric Double Oven
F64 error
The F64 on those oven`s is indicating the onboard watchdog ( control board ) has detected the cooling fan for the lower oven isn`t being detected or isn`t funtioning.
That may or may not be the problem though. I`ve found often it is actually the "sail switch" located in the vent of the oven ( at the bottom where the unit exaust`s ) is stuck either due to grease or being damaged during installation.
You`ll likely want to call in a pro to actually determine what is in fact initiating this error code, but it is definetly related to the lower cooling fan circuit.
Let me know if I can assist you further. Thank`s for visiting "fixya" for your oven inquiries and good luck.
If you feel as though you are capable to service this on your own let me know and I`ll attempt to guide you.
macmarkus :)
Mar 25, 2010 | Thermador SC302T Electric Double Oven
Bottom Oven Does not work - F64 Code on Panel
If you look under the bottom door you will see a 3/4" tall slot the entire length of the door. This is where the cooling air blows out. In the middle of this slot is the air switch enclosed in a 5" long metal housing. You can see a thin metal paddle sticking out of each side of the housing. These paddles are spring loaded to angle slightly back. When the fan is on, the airflow will push the paddles forward. If they do not move forward, then you will get the error code. The simplest solution is to vacuum out all of the normally collecting dust that keeps the paddles from moving. To better access and clean the area, the black trim piece that forms the slot can be removed by unscrewing the two retaining screws. That can be more easily accomplished by first removing the lower door. This is very simple. With the door fully open, rotate the small metal clip on each hinge so it hooks over the protrusion on the other part of the hinge. Then lift up on the door (close it part way) and slide (pull) the door and hinges out of the hinge slots. There is no need to remove the entire unit from the wall.
Sep 24, 2006 | Thermador C302U Electric Double Oven
Ovens Logo
3,671 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
