Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Not sucking up waterl - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
How do i make sand on little alchemy
Rainbows don't really trap as much in the water as the salesman says. That's why they don't want you to suck up drywall dust. To the extent that dust floats in the air, it also stays just as suspended in the bubbles as they go through the tank. When the bubbles pop at the surface of the water in the tank, much of the airborne dust isn't trapped and gets sucked through the motor. The idea of sucking gunpowder through a Rainbow sounds interesting. There's sparks flying around the commutator in that motor and you could possibly have dust going through. Id like to watch you suck up gunpowder.....from a distance.
Dec 06, 2014 | Rainbow Vacuums
Vacuum not sucking from the brush bottom
Probably clogged at the intake. remove rug plate and check intake. Broken belt is other possibility. #5 belt. This a ver basic vacuum, so not much to go wrong.
Jan 02, 2014 | Dirt Devil M084600 Dynamite Bagless...
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
My dyson sucks good untill i put handle down
Try moving the floor/carpet selector dial on base of vac back and forth, from floor to carpet repeatedly, at least 5-6 times....it may be stuck
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Filter sucks against top creating low suction
Beckyanneok,
See my post with the same problem (described in painful detail) at:
http://www.fixya.com/support/t329235-no_vacuum
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Don.
Apr 30, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,000 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
