Question about Pitco Frialator 40CNG Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
  • Pitco Frialator Expert
  • 684 Answers
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Posted on Jun 08, 2011
PitCo 40c fryer no gas cuming out of pliot
Possible dirt in the pilot gas orifice
Aug 03, 2015 | Kitchen Appliances - Others
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
My pitco frialator fryer's pilate wont stay lit
Check the thermopile, it should be free of soot or any form of dirt. Pilot flame quality must be good. Gas pressure should meet the requirement as stated on the nameplate.
Oct 22, 2010 | Pitco Frialator 35C Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Pilot light will not stay lit
You can not check a thermocouple by resistence. You have to check it by millivoltage when it is hot and sensing it should be above 500mv. I would be willing to bet that you have some type of particulate in the gas valve that is causing this problem.
Jun 23, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco fryer pilot out
if you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Jun 19, 2008 | Pitco Frialator 35CD Deep Fryer
Pitco Frialator 40CNG Deep Fryer Logo
343 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
