Question about Cameras
Cannon Power Shot A560
All of a sudden in picture mode the shutter does not open the screen is black but opens in video mode is there some setting I hit on accident?? changed batteries didnt work and everything else works.. stumped
  • Cameras Master
  • 4,738 Answers
Did you accidentally hit the lower left "Disp" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Posted on Jun 19, 2008
SOURCE:
My Nikon coolpix l820 the screen doesn't work on camera setting but does on the video camera setting
hi,
when the still camera works the shutter of the aperture and iris is opening for a limited time, if it opens without limit the excess light will enter in and the result will be blurry picture, if the shutter is not opening the picture will be dark. in movie mode the shutter will be always in opened state, so I think there may be fault in shutter.
in some cases a slight jerk giving to cam when you depressing the snap button will reset the shutter and will work normally.
Nov 24, 2015 | Nikon COOLPIX Cameras
My exilim camera is taking black pictures. Two days ago it was fine and all of a sudden when I turn it on the display screen and previous pictures are dark. When I take a picture or video now it is just...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 28, 2011 | Casio Cameras
My canon PowerShot SD750 digital camera screen suddenly turn black(dark ), I can not take picture because there is no image shown on screen. I still can record sound on video,but no image. what is going...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
Dec 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Indoor pictures are fine; however, when I take a picture outside, it is "white." Have I accidently changed a setting? Thanks for your help.
First make sure your mode selector dial is set to the red camera WITHOUT an M next to it (ie it's in Auto and not Manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A430 Digital Camera
My S2 IS all of a sudden cannot see anything out of either the lcd screen or view finder. I can see all of the settings on those but just a blank screen. Yes, my cap cover is off. Any thoughts?
Jun 08, 2009 | Canon PowerShot S2 IS Digital Camera
Blank picture screen
Did you accidentally hit the "DISP" button on the back of your camera? It manually turns the LCD screen on and off to save batteries.
Jun 21, 2008 | Canon PowerShot A520 Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
