Question about Canon imageRUNNER C3200 Copier
My canon ir 3200 have a code error E 732 I dont now what to do
  • 71 Answers
my  canon  ir - getfile.asp?rid=1258 March 3, 2009 Product : imageRUNNER C3200 / 2620 / 3220 Title : E732 and E733 are Displayed, when Copying off the Glass or when using the DADF
Error :
Error codes of E732 and E733 are displayed, when copying off the glass or when using the DADF. The Control Panel would go blank and the processing data light would continue to blink. After a few minutes in this state; the copier was rebooted and the codes would resolve themselves, but would eventually return.
Workaround :
First, try reseating all the connectors to the Reader Controller, Interface PCB, and DDI-S PCB. Next,
check for proper voltage to all three boards.
In this case, a defective DC Fuse PCB caused the error codes. An intermittent loss of voltage to the Reader Unit caused the machine to code out.
Note:
The part number for the DC Fuse PCB is FG3-3020-020.
Canon USA, Inc. Systems & Technical Support Division
Posted on Jan 02, 2011
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Canon ir 7200 error 732-001
Hello there
Possible faulty Main Controller but see similar problem here from the Copier Technicians forum
http://www.copytechnet.com/forums/canon/9116-irc2880i-e732-001-code.html
Sep 22, 2014 | Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
Canon ir 7200 error code 732-001
hello i have problem with canon ir7200 error code 732-001
Aug 22, 2012 | Office Equipment & Supplies
I have a Canon IR C3220, and i started off with the yellow drum error code, which i just replaced, and now I'm getting error code E000020-0125. Can you please help me?
It is possible the front door plastic door interlock for the SALT sensor shutter is broken or not in place, (see picture below). If the shutter is not actuated by the interlock, the SALT sensor will error out when trying to perform ATR measurement resulting in an E020. Sub codes will be related to yellow ATR measurementsince it is the first color laid down on the ITB for ATR measurement.
Sep 07, 2010 | Canon imageRUNNER C3200 Copier
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR 3200 Error code e00677-004 no print or copy clears momentarily after reboot, but returns
ok you have a hard drive error problem that is what the code refers to need to replace the hard drive, try to scout around for one out of another machine somewhere and put it in otherwise if you get a new HDD you need to reload all the machine firmware and you will need special tools for that and only canon technicians have access to that stuff,
as i am a canon tech myself
Mar 30, 2009 | Canon imageRUNNER C3200 Copier
ERROR IN IR 8500
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
Dec 25, 2008 | Canon imageRUNNER 8500 Copier
Canon ir c 3200
It is a fuser heat error. Try to reset the machine from the error code. If problem persists you have the check the fuser for damage. Could be a thermister, thermoswitch, or faulty heaters. To clear error, service more function/clear/error/ok/ exit service mode and cycle power.
Jul 13, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
483 people viewed this question
old marine
old marine
