I have a Zanussi FJD 1266W washing machine (product code: 91451352500) & I keep getting error code E90 flashing up, can you tell me what is causing this problem & what parts are required to fix it. Many Thanks Paul Denning
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
  • 1294 Answers
SOURCE: washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Jan 01, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
Posted on Feb 28, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    Can anyone help ive got a zanussi FJDR 1466 W. e91
    I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
    Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
    Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
    Hi zanussi fjr 1254 w error code e90 what does
    This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
    Thanks
    Jul 01, 2009 | Zanussi Washing Machines
    My Zanussi washer will not start and the end light flashes 9 times. Do you know whats this means
    This indicates error code E90. Sometimes its a loose connection to the front control board. But it would usually require a replacement one Zanussi call them a user interface hope this helps you.
    Dec 17, 2008 | Zanussi FJS1225W Front Load Washer
    Washer whilst washing keeps flashing up with E90
    Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
    Zanussi washing machine
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    46 people viewed this question
    Top Washing Machines Experts
