Question about HP Photosmart C5580 All-In-One InkJet Printer
Cannot scan when using Picaso. Get message "unable
  • 1 more comment
  • olern Nov 13, 2010
    I am using Windows XP. I have used the printer for 2 years and had no problems. Everything else works on the printer but not the scanner.
    This worked perfectly. Thank you so much!!!!!!
    Word perfectly. Thank you so much!
  • 340 Answers
What is the operating system that you are using?
Posted on Nov 13, 2010
  • Lori Langley Nov 13, 2010
    Here is our first step in troubleshooting the issue of the scanner. Follow these steps to run the scan diagnostics on your printer/scanner. Let me know what the results are and we will go from there. This will give us a better idea on which direction to take in resolving the issue.
    Step one: Download the Scan Diagnostic Utility
    NOTE: The HP Scan Diagnostic Utility might not be available for all HP products, particularly older products. It is available for most products, however, and in most languages. This tool is available only for Windows operating systems.
    1. Click on the following link to download the utility http://h10025.www1.hp.com/ewfrf/wc/softw...
    2. Link to tool (right-click)File size
      HP Scan Diagnostic Utility 2.24M
    3. Make sure that your computer meets the system requirements, and then click Download .
    4. When the Security Warning dialog box opens, click Save . The Save As dialog box opens.
      Important: HP recommends that you save the download according to the following directions to make sure that you can easily access the tool again at a later time.
    5. Click Desktop in the drop-down menu, and then click Save . The Scan Diagnostic Utility downloads and saves to your desktop so that you can access it at any time.
    6. When the Download Complete dialog box opens, click Run on the Security Warning dialog box.
    7. When the tool finishes installing, click Finish . The Scan Diagnostic Utility opens automatically with a list of installed products.
      Tool didn't open automatically?
      On your computer desktop, double-click the Scan Diagnostic Utility (SDU) icon.
    Step two: Run the Scan Diagnostic Utility
    1. Press the Power button ( ) to turn on the product, if it is not already on.
    2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
      Product not in the list?
      If your product is not in the list, reinstall the HP product software.
    3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    Step three: Resolve diagnosed scanning problems
    1. In the Scan Diagnostic Utility results screen, look for items with a red X ( ) next to them. Items with green check marks ( ) are fine.
      • If you see one or more red X ( ), continue with these steps.
      • If you see only green check marks ( ), the tool did not find any problems.
      • If you see any yellow exclamation points ( ), treat this as a warning. The suggested fix is optional.
    2. Click the item with the red X ( ) to select it, and then click Fix . The Scan Diagnostic Utility automatically fixes the diagnosed issues, if possible, and then displays results on the screen. Repeat this step for all items marked with a red X ().
      Can't click the Fix button? If the fix button is unavailable (grayed out), follow these guidelines:
      • Look at the instructions in the Scan Diagnostic Utility. There should be instructions on what to do next.
      • Examine the Power button ( ) on your product. Make sure that the product is on, and that the power light is solid, not blinking.
      • Make sure that the USB cable connects securely to your computer and to the product. The USB icon ( ) on the USB cable generally faces up when the cable connects to the computer correctly.
        If the Fix button is still unavailable, you must reinstall the HP software.
    3. When you finish fixing all the diagnosed problems, a pop-up window opens. Click Test Scan . The product performs a test scan, which might take several minutes.
      • If the test scan is successful , you do not need to continue troubleshooting. You resolved the issue.
      • If the test scan is not successful , click HP Update or Help in the Scan Diagnostic Utility for more troubleshooting options.
Unable to write the file to "Destination Folder"
A recent (Dec 2015) Windows 10 update seems to have removed the access required for the service account used by Brother to write to the hard drive. This fixed the scan function for me...
  1. Navigate to the directory where you write the files (C:\Users\YourID\Pictures\ControlCenter3)
  2. Right click on the Scan directory and open Properties.
  3. Click Security tab.
  4. Click Edit
  5. Select WMPNetworkSvc
  6. Allow Full Control
  7. Click OK
Nov 11, 2011 | Brother MFC-6890CDW Printer
Tip
How do I connect my iPod to My Network
<p>The iPod Touch is the only device in Apple's line of portable music devices with embedded networking capabilities. When you enable WiFi on your iPod Touch, the device scans the area for available networks and displays a list of results. From there you can connect your home network or Wi-Fi and use the Internet to email, instant messaging, Web browsing and other applications. <br /> <p> <br /> <p>1. Touch the "Settings" icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Select "Wi-Fi" menu item. <br /> <p><br /> <p>3. Move the slider at the top of the window of the "Off" to "On" position. The phone will scan for nearby Wi-Fi networks.<br /> <p> <br /> <p>4. Tap the name of the network you connect to your iPod Touch. <br /> <p><br /> <p>5. Enter the password for the Wi-Fi network you selected with the keyboard on the screen. <br /> <p><br /> <p>6. Tap "Done" to connect to Wi-Fi network using the password you entered. When the Wi-Fi icon appears on the top screen of the iPod Touch, you'll know the connection is successful. <br />
on Aug 09, 2011 | Apple iPod touch
Scanner posts message "unable to
Don't give yourself grief. Don't argue with it.
Uninstall and reinstall printer prog
Download your complete version up-dated from www.hp.com
Mar 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer won't print. It will also say "unable
Ok, for the printing part you should check the following:
-connection between printer and computer
-make sure the machine is not in power save mode
-make sure machine is online; click start, printers, choose printer and make sure 'Use Printer Offline' is unchecked
-reinstall the drivers from here: http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/mfc5490cn_all.html?reg=as&c=au&lang=en&prod=mfc5490cn_all
Now regarding the scan error, seems to be a mechanical error. Remove and objects that might stop the scanning to proceed. Also, check the manual for Troubleshooting on the link above.
Nov 14, 2010 | Brother MFC-5490CN Flatbed Inkjet...
Scanner will not operate when diamond is pushed
It takes almost a minute, but it needs to be connected to a computer with scanning software installed. After you push the diamond the software in your computer starts and you select how to scan and save and where to send the picture after scanning. I just use Picaso that came with Windows Vista. You need to go to control panel/scanners, and make sure your scanner is seen.
Dec 20, 2009 | Canon MP610 Photo All-In-One Printer
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5580 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
