Question about Haier Water Dispenser w Fridge Refrigerator
My Haier water cooler has 2 problems. One the small fridge at the bottom no longer works and then today my cold water spout is not letting me get any water. Nothing seems to be wrong with the hot water.
  • 66 Answers
SOURCE: My Haier Mini Fridge comes
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Posted on Nov 12, 2008
landsend
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Posted on Jun 07, 2009
intisarkhan2
  • 23 Answers
SOURCE: I have a Maytag MSD2456DEB side by side
freezer side check fan working check damper to ref. side.
Posted on Nov 17, 2009
  • 1891 Answers
SOURCE: my small haier fridge just makes a clicking sound
the clicking niose is the compressor relay . and needs to be replaced . this may not get the comp going as it may be stuck or motor windings burnt . . then replacement of compressor in needed . mm /hope this hepled .
Posted on Jan 17, 2010
Haier WDNS401VS manual
My haier does not dispense cold water its dispense warm water
Nov 25, 2011 | Haier Water Dispenser w Fridge...
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Jul 31, 2009 | Refrigerators
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Have a Haier water cooler with the fridge compartment in the bottom. Compressor on the unit just started running continuously, instead of cycling on and off. now the chilling bowl that cools the water...
removed one of the two thermostats... the one that controls the temp in the lower refrigerated compartment. Now the water cooler functions correctly but the lower refrigerator is not cold enough to keep perishable food in it, but its better than it was.
Dec 09, 2008 | Haier Refrigerators
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
I have a Haier 18 bottle cooler. And while it keeps the wine cold, it almost never shuts off. I rarely open the door to let the cold out, but the refrigeration unit never stops pumping. The fans are...
No, i don't believe u are. these small fridge will run longer during the day as they have limited cooling capacity and the heat load is higher during the day. there could also be a problem with the cooling system and if there is one, the problem will become more noticeable and it will stop cooling. otherwise, i would leave it as is
Jul 21, 2008 | Haier Refrigerators
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Fridge won't quit running and get cold
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
Aug 04, 2007 | Haier HTQ21JAAWW Top Freezer Refrigerator
Haier Water Dispenser w Fridge Refrigerator Logo
176 people viewed this question
Top Haier Water Filters & Coolers Experts
Tom Chichester
Are you a Haier Water Filter and Cooler Expert? Answer questions, earn points and help others
