Question about Vacuums
After not using my binatone f430 for approx 2 months doesnt seem to want to charge up? red light not coming on (shud be on showing charging) any ideas
  • Vacuums Master
  • 6,993 Answers
the problem is either from the charger or the battery of your Binatone f430. But most likely, the problem should be from the charger. The charger might be defective and maybe that's why its not charging the unit.
You can borrow a charger from a friend and test it with the unit, or test the charger of your Binatone f430 with that of your friend's (if any).
This will reveal if actually the problem is from the charger or from the unit. If from the charger, you will have to replace it. But make sure you confirm the charger is actually bad before you make any replacement.
Good luck.
Posted on Nov 12, 2010
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
My roomba appears to charge and has a solid green light when finished, but when I take it off the charger and try to turn it on I get the 4 note song and blinking red light like the battery is low even...
This is totally happening to me too. It apears to charges, works for about 2 minutes then stops and the red light is on as if its not charged. I am thinking to buy a new battery but they seem to be about AUD$50 and if thats not the problems I have wasted my money. The repair centre in Melbourne was so rude on the phone I wont send it to them as they cannot say how much it will cost me
Feb 13, 2011 | Roomba Robotic Floor Bagless Vacuum
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Hi, this is our third Dyson DC-16.. the Trigger was shorting out on the first two.. Now we have the third one for about a year.. on charge when not using it.. don't use it every day, but for quick pickups...
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Battery not charging
The charger may be bad. The red light shows that power is applied to it. So usally, unless the light itself is bad, no red light, no power.
Dec 27, 2007 | Vacuums
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
