I hav a teac hdr2700t when we connect it there is no signal from any channels. The old tuner picks up all the channels fine so it is not the antenna. It switches on fine and loads all the channels but will not show them. Trying to access the main menu wont happen as it will not appear on the screen. We have it on the right avi as it loads on the screen which you can see then nothing. not sure what to do
  • 1139 Answers
SOURCE: internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
Posted on Sep 21, 2007
  • 1285 Answers
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Posted on Jul 26, 2010
  • 301 Answers
SOURCE: Hi, Can you tell
Posted on Dec 17, 2010
  • 1126 Answers
SOURCE: I have a Vizio VW42LF TV that is 2 yrs old.
The TV processor could have some garbage in it do to a small power surge and if you leave your TV unplug for 40MIN., then that will reset it bad to normal, and if tuner still looks snowy and not getting channels, then the tuner, or main TV module needs replaced.
Posted on Dec 19, 2010
  • 1126 Answers
SOURCE: We have a TEAC HDR2700T
It might have be hit by a small power surge and if you unplug the the signal source and the TV from the wall and leave them unplug form4 0 MIN., then it will reset back to normal.
Posted on Dec 21, 2010
My Loewe tv won't pick up a signal in my new house. The old tv works fine :-(
Have you selected the antenna or cable tuner and done a channel search?
Oct 24, 2016 | Loewe Televison & Video
My tv says no signal on one channel, how do i get that channel back ?
If you are getting an OTA signal, you should check your antenna, any amplifier or splitter and the station's status. The "No signal" message indicates that the signal is not strong enough to be resolved by the tuner.
1) Is your antenna pointing in the correct direction? Outdoor antennas can sometimes turn in the wind. Reset the antenna to the correct direction.
2) If you have a splitter dividing the signal between TVs or other devices, try a direct connection to the one TV that isn't receiving the channel. Similarly, if you have an amplifier in the system, try using the antenna without it. (I have seen an amplifier become a filter for select channels when damaged.) The only solution is to replace the device or omit it. (In my case, some channels require amplification; thus we replaced the amplifier.)
3) Has the station's local transmitter/repeater been damaged? Check their news feed. Towers fall and transmitter components can fail.
You could try and see if another tuner picks up the signal. Some low end tuners are more sensitive to signal strength. If you are getting the station from another source, check with the provider. We recently lost some of the local PBS stations due to problems with the cable provider's feed. Only one TV is connected to the set top box.
I hope this helps.
Feb 13, 2015 | Televison & Video
LG47lc7df Antenna signal
It is possible you are experiencing tuner problems. If you cannot pick up any channels regardless of the antenna used, sounds like tuner problems.
Nov 02, 2013 | LG Televison & Video
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
Panasonic th-c42hd 18 stopped receiving middle-numbered channels from my outdoor antenna. Auto Scan feature (& manual scan) only picks up a couple low- & hi-numbered channels. Is it possibly the...
Tuner is possible but check set is in air and not cable band---I would connected a dvd to see rear inputs ok---there may be a way to route the antenna signal to one of those and bypass the tuner(any box with its own tuner can be used.)
Nov 06, 2012 | Televison & Video
Emerson hdtv does not pick up any antenna signal
With digital OTA TV signals, a lot of things could cause you to fail to pick up a signal on any channel. First, do you have an indoor or outdoor antenna and how far are you from the transmitters for you local stations? Digital signals are either enough to for the tuner to interpret or you get no signal. Next check that the antenna is pointing at your stations' transmitters. Use or to check the direction for your location. Antennaweb assumes an external antenna and provides a very conservative list of stations.
Check for buildings, hills or tall trees that might block the signal to your location.
If your antenna is providing a signal to several TVs, try a direct connection (taking out the splitter). You may need an amplified splitter to minimize the signal loss. Note: amplifiers (whether at the splitter or part of the antenna) can fail and become signal filters (blockers) instead. The direct connection tests this as well.
If another TV does pick up the signal from the antenna (at this point), then the tuner may have failed. It may also just be a weaker tuner compared to the other TV. Surges (for example, lightning strikes) can cause a tuner failure. In that case, you need a new tuner. (a stand-alone tuner like the converter boxes might work) or try a site like, or SearsPartsDirect lists the tuner here: .
This TV was made by Funai so you may see other TVs that use the same part.
I hope this helps.
(I have two TVs with different quality tuners. With one, when the antenna shifts slightly out of place, I can lose the ability to tune in the channels from the closest transmitters. The other TV does not lose the signal until the antenna rotates more than 90 degrees from its usual position.)
May 27, 2012 | Emerson LC320EM9 32 in. LCD HDTV
No signal without a digital convertor box.
You must have a tuner, but the one built into the TV will work fine. Have you scanned for available channels after connecting your antenna?
Jun 28, 2009 | Polaroid 1511-TLXB 15.4 in. LCD Television
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
May 15, 2008 | Insignia Digital-to-Analog Converter for...
Can't pick up all the signals
I always tell people to carefuly read their instruction manual and consult the product tech support before determing that there is actualy a fault with their unit.
If sounds like the tuner module or the controler board for the tuner may be failing, or there is a power supply distribution fault to the tuner section and or its controler. This has to be service by the manufacture.
One of the criteria I recommend when people buy an expensive appliance or TV is to make sure that there is local authorized service. I also recommend an extended warrany for expensive items. The warranty is like insurance. You may or may not need to collect!
Jerry G.
Apr 17, 2008 | Televison & Video
Televison & Video Logo
400 people viewed this question
Top Televison & Video Experts
